Ok who has a copy of FAST that covers late models?
PM35-600544
Need the options list.
I'm assuming you don't need them badly translated? Let me know if you do though.
Edit: New pic which includes the rest of the details instead of just options.
hi thanks so much for getting on this request !!
can you tell me what u see from the info like what my car came with factory etc for equipment standard
I see it has different bumpers, skirts, has the v spec areo kit im sure, has the bigger brakes ....
I would of asked in my own country Canada .... but the members of GTRC are not quite as informed as u guys are in the skyline game
.... so ask the experts
i have Brembo Brakes are those listed by chance
thanks so much
Edited by Collector-1313
Hey mate unfortunately with these earlier models it's a little more difficult to grab the info for the options. With later models(33 onward, 93 or so onwards it seems) it gives you a box with all the oprions for that particular car like up the page but for 32 and earlier it gives you a bunch of charts etc that you need to look through so it's a bit harder to work out what's what.
oh i see .......
okay thats a shame for me anyways cuz i kind of started a up roar of mixed emotions on this car .....
people are hot to say what it is and what it isnt but no one can say for sure hahahah
if you do happen to rip some info out of some dusty area of Nissans history please let me know
and sorry for not introducing myself, i am a new GTR owner from Canada !!!
I will be using this form rather than GTRC for the vital info that matters !!
thanks from Canada Everyone !
if theres anymore info anyone please share
hey thanks ,do you have # for skyline badge between tailights ..should be the same as your car ..nissan told me i need to buy complete panel to get badge.. :wacko:
Looks like you do have to buy the whole trim panel :(. The S2 ones don't come unpainted either you have to get it in a factory colour. 84810-26U07 is the KR4 part # but not sure if that's the silver your car is, should be though. Just shy of $350 through Amayama :S
    • Is anyone running these axles? R32, R33, R34 GTR front Axles. shafts itself rated 950hp. Suit all RB26 engines Croydon, Melbourne, Victoria Would be nice to pay half the cost of Driveshaft Shop Axles. I'm building an AWD S13 Coupe that is very low ride height (high cv angle) compared to stock R32. Has an RB30 with appx 600whp. Just looking for feedback. Thanks, Josh- https://www.instagram.com/feng_shui_garage/
    • Been a long time since r31 got some love, my brother dropped a shitbox ls1 crapadore in my lap to fix up.  Put a wiper motor in as the flooded one was no longer alive.  got windscreen wipers now. Time to clean respray and install back in the titanic  IMG_0505.mov
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
