Dark26
Posted Yesterday, 06:48 PM
Don't think I can run that through FAST. It should be the chassis number like BNR32 and then 6 numbers. What car is this from? Can you look on any of the plates on the firewall for it?
HR31-057324
:rolleyes:
Edited by dw13098
Chassis number: KBNR32RXFSLMZG
Build date: 12/1990
Colour: KH2 = Gun Grey Metallic
This is a regular GTR, being that it is a 1990 model and there is an X in the chassis number. Not too sure what LMZG means. I did some googling but came up with different results.
Can someone run this one - BNR32-310633
Thanks in advance.
Model: KBNR32RXFS7NAA
Year: 06/1994
Colour: 732 = Black pearl
Regular R32 GTR. The N before AA could be SRS airbag, but I'm not too sure if this guide I'm reading is correct or if I'm reading it correctly.
HR31-057324
:rolleyes:
HR31-057324
HR31-057324
Can anyone see if this works on their FASTED
HR31-057324
please please please!!!!
Complications in your VIN, it cannot narrow down a specific build date...
Give us some more info like what engine it has in it?
Auto or Manual?
Thanks.
thanks mate, just wondering do you know what spec code SPOI6 refers to, I know that the TELV2 = the multi AV system with TV and possibly addvest sound system option.
Cheers
Hey man!
SPOI6 = No air spoiler... :blink::)
Could mean the car didn't come with a roof spoiler..?
BNR32-220432 Appears to be a '92 GTR in TH1 blue. Otherwise stock expect for susp and nismo control arms.
What can you tell me? RB26 timing cover has a riveted plaque that reads "Nismo" (engraved), then "Tuned by Nismo Omori Factory" Serial No. E012 (engraved)
What can you tell from VIN?
The VIN matches your description.
Check ECU and Turbo Part numbers to confirm if been modified by Nismo.
Post pics or send to me and I can have a look, thanks.
Bncr33022986 suppose to be BCNR33022986, "N" and "C" other way round :)
Thanks
A R33 GTR V-Spec in Champion Blue, is your GTR a LeMans Edition?
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
