yea preety sure, mine is the same color KH2 ( looks gunmetal grey with red and blue 'perl'), the color code is actually on the compliance plate(firewall one, not import plate)), just above the engine type, RB26DETT . See port #1713, his paint code is KH2. This will confirm FAST info, and if the cars has changed color. KH2 is also refered to as gunmetal grey sometimes
PS midnight purple is a rare colour, price me thinks, codes are
LP2 (R33)Midnight Purple (no Chromalusion, has 2 pearl tinters Violet & Red)
LV4 (R34)Midnight Purple II (Chromalusion Tinter KK760 Absolute Purplene & Vilot Pearl)
LXO (R34)Midnight Purple III (Chromalusion Tinter KK700 True Blazberry Prizm & 2 pearls red & Violet)
see Here for ALL the Paint codes
cheers man.
i have no vin plate, and its definately midnight purple.
I'm Thinking respray job :)
could i please get mine fasted. 6U9000ECR33017453. thanks.
can I get a check on BNR34-006450 please
someone check this one out for me?
6u9000bnr32001624
Edited by BundyBear
got a japanese Nissan FAST DVD
installed it and when I clicked on nissan fast button it gave me parameter incorrect.
any tips how to install this thing on an XP?
Try this
README.TXT
or this
showthread.htm ^^^ Probably betta
Cheers
that's ok I found it. I need to change the font from the settings. it's missing jap font so it won't load up.
but now with Courier - it's still showing Japanese menu in gibberish so I might have to install a USDM front end and use it with JDM data.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
