Hey guys,
I tried searching for a while but couldn't find much, just a whole lot of reading that wasn't answering my question.
Can anyone tell me any afc that can be tuned via a laptop? And which one would be the best for a RB20
I find it easier tuning a laptop then the hand controler.
Any help will be very appreciated
Thanks
there is no apexi afc that can be tuned by laptop. i think you are confusing the powerfc with the afc or safc. do a search on both to work out which one you are thinking of. there is laptop software for the powerfc
he didn't say apexi afc, he just asked for any afc.
the greddy emanage can be tuned with a laptop. and for about an extra $70 you can get an ignition harness to tune the timing as well. but it doesn't come with the software. it is about $250. but you get more tuning range (air/fuel wise) with a safc neo.
Edited by mad082
Thanks
That sounds what i am after
piggyback emanage
piggyback safc
Safc $370
E-Manage Ultimate $650
GReddy Complete Harness Set $124
GReddy Supplemental Harness $65
Software $140
piggyback emanage
Emange Blue $370
Emanage Injector Harness $56
Emanage Ingnition Harness $56
Software $140
standalone powerfc
PowerFC $930
software $500
  • 2 years later...
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
    • I think Fitmit had some, have a look on there (theyre Australian as well)
    • Hah, fair enough! But if you learn with this one you can drive any other OEM manual. No modern luxury features like auto rev-matching or hillstart assist to give you a false sense of confidence. And a heavy car with not that much torque so it stalls easily.
    • Actually, I'd say all three are the automatic option. Just the different trim levels. The manual would be RSFS, no?
