Alright,
I am on the market for a new ecu for my R32 GTST , main requirement is it has to be MAP, i have narrowed it down to eigther Microtech or Linkecu.
I am after your personal experience with both these Brands to help me decide on eigther unit
Cheers
Cameron
https://www.sau.com.au/forums/topic/128762-microtech-or-linkecu/
Has to be Map so can run without piping, plus my afm's on its way out :)
Mercury or Millennium Motorsports will be tuning it they both have said eigther is fine.
current mods are
higmount
t70
Front mount
Hybrid dual stage boost controller
HKS Cam's
HKS Cam Gears
Bosch 040
550cc injectors
Future plans in progress atm
Bore too 82mm
Rb26 crank and rods
Forged tomie pistons
Port and polish the head
cheers
Cameron
Edited by murrayis
If you dont want to spend Motec or autronic money - i would have thought a Apexi Power FC D -Jetro would have been a wise choice for a 32?
Link is crap and Microtec I cant comment on as Ive never used one or been in a car with one.
spend the money once and once only. go autronic. nothing but good reports and i have only ever seen great results with them. get yourself a quality tuner who knows his stuff and build up a good relationship. you ll get the power u want!
    • If there's enough meat in the housing where you want to put the M12 adapter, then do it, but be aware that if/when you f**k that up you'll probably be repairing it before doing anything else. I'd just drill it out and tap ina 1/4" thread. No need for rocket surgery when the next most obvious thing will do. You could throw a 1/4 x 1/8 bush in there and use the same fitting you intended to use.
    • Is the only issue that the oil catch can is getting filled on hard runs? I'd be thinking more about oil control issues rather then the head lifting, especially as you aren't seeing spiking in the coolant pressure.  Do you need restrictors in the head, or better drains from the head? Does the sump need venting to the catch can?
    • Tried to make 1/8npt threads into compressor house of the turbo for my EBC. Threads got fu#ked and ended up with and elongated hole, so I do have good amount and nice threads 90% of the hole but 10% I only had 1-2threads there and rest of it is flush on that side of the hole.. So my idea is to do M12 x 1.25 to AN4 with braided lines instead of 1/8npt to 4mm vacuum silicone hose.  and hopefully get a better thread. M12 is quite big and AN4 is a little bit bigger than 4mm (4.9mm inner diameter braided PTFE hose). but this should work. Thoughts? Otherwise I will weld and adapter onto the turbo.
    • Looks great, I hope everything is working well after all that time!
