Finally got my compliance plate and registration yesterday.
Been driving non stop since then and the car hasnt let me down. ...Everthing I had hoped for.
Used the Maguires products today and shes come up a treat.
First used soft gel wash
then paint cleaner
then water finish polish
..and will wax it tomorrow
is this the right way to do it? Maguires have got so many products that seem to do similar things.
Was hoping to see some of you tonight so I could have a run. Drove everywhere and couldnt find anyone willing to have a bit of fun.
Be seeing ya
says the one in the very shiny clean polished R33
https://www.sau.com.au/forums/topic/12887-bout-bloody-time/
am certainly loving it.
Car is a stocker but good things come to those who wait. Im a bit worried about my license though. Its such a smooth and quiet (stock exhaust) car that u dont even realise hoe fast your going. I only have 3 point left and crossing my fingers.
Will post some pics soon (after I wax it)
There IS a question in my first post!
https://www.sau.com.au/forums/topic/12887-bout-bloody-time/#findComment-241750
No way that is completely wrong the way you have washed it! you haven't given meguirs enough money that way you need to buy the following and place on in the folowing way
1. shampoo that is a nice yellow colour that gets rid of air of the paint
2. a different class 2 type that gets rid of any left over air from the paint incase you didn't get it off from the 1st wash
3 class 3 air off paint remover
4 car shampoo & wash
5 car shampoo and wash cleaner
6. car shampoo and wash cleaner cleaner
OK honestly i think meguirs is a VERY good product but i really think they have gone over board in there range and are hopping for people like us who car dearly about our cars to buy everyone of their products this i think is all that you need!
1. First used soft gel wash
(2. deep cut polish or swirl remover if your car needs it)
3. finish with Gold class wax/polish
these are the only 3 products i have been using for the past 1. 5 years and works a treat... anything else really is overdoing it. Even my friend who details porsches told me the same!
https://www.sau.com.au/forums/topic/12887-bout-bloody-time/#findComment-242144
My car sometimes after starting seems to idle eratically for a few seconds before idling normally.
Does anyone know what might cause this?
ALso how many ks do you guys get out of a full tank when driving at a medium to hard level?. Probab only been getting about 250-300 myself
https://www.sau.com.au/forums/topic/12887-bout-bloody-time/#findComment-243818
I dont drive my car hard 100% of the time on average I get 450-500km's out of a tank. I generally change gears at 3000rpm around 90% of the time, whilst 7% is around 5000rpm and the rest around 6500rpm. If you only got 350km's out of a 60l tank, I'd suggest you have been floggin it far too hard, back off or you will do some damage, especially if the car was complianced with cheap oil also are you using BP ultimate98?. I get the same rev problem when starting the car, happens maybe once a fortnight... dunno what it is, could be something to do with the AFM.
https://www.sau.com.au/forums/topic/12887-bout-bloody-time/#findComment-243900
whats the point in having a turbo if your going to be changing gears at 3000RPM.
https://www.sau.com.au/forums/topic/12887-bout-bloody-time/#findComment-244503
ImPrOvIsE, if i drive, and shift at mostly 3000rpm - 4500rpm i'd probably get around 400km out of a tank, depends if you're driving on boost a lot too, be a lot different if you accelerate softly up to 5000rpm without generating much boost, than planting it from low revs to 5k. I have taken it easy for a whole tank before and managed 480km (city driving) and the fuel light had only just come on (sits on E for ages before the fuel light comes on).
paul 6000rpm all the time? how often you change your oil and oil filter?
chris.
https://www.sau.com.au/forums/topic/12887-bout-bloody-time/#findComment-244518
The point is I like to get good milage and prolong the life of my engine and most of my driving is done going to and from work at peak times. The point of having the turbo is that when its late at night and I want to fang it I can. If you wish to drive like a ****nut and change gears *all* the time around 6000+ rpm go for it. Just dont whinge about your poor mileage. I'll ask my questions again, do you use BP Ultimate 98 and what engine oil was put into the car?
https://www.sau.com.au/forums/topic/12887-bout-bloody-time/#findComment-244840
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
