Hi Guys,
I am presently looking to replace my stock catback exhaust to any quiet performance exhaust catback system out there. Wondering anyone here would have some clue on the brand. Would prefer similar loudness like the stock exhaust but more performances. Thanks
https://www.sau.com.au/forums/topic/128885-quiet-performance-exhaust-for-r33/
Hi mate,
Legalis-R by Fujitsubo and Kakimoto.R by Kakimoto are two exhaust types/brands that are known to be quiet and also high-performance.
Check:
http://www.fujitsubo.co.jp/
http://www.kakimotoracing.co.jp/
Both in Japanese but relatively easy to navigate....as I recall, a business on these forums - BT-Revolution can get either for you brand new.
Edited by RaseR
Hi mate,
thanks for the information, now where can i get them? any idea? pardon me, i m pretty green to skyline at the moment.cheer
yeh im after a good cat back aswell which performs well, but is quite quiet. I went to the exhaust place near me and they were gonna do a cat back with a lukey muffler? Anyone know if these are any good?
U ain'd heard quiet until you hear mine...Apexi Super Megaphone. Another forum member has the same one and its quiet as. A few times I have been driving thru carparks and ppl walking in front of me don't even know a car is behind them...
There is one on sale from Afro is you wanna chk his thread out...
http://www.skylinesaustralia.com/forums/in...27&hl=apexi
When you give it a bit of throttle gives out a very suttle roar but nothing that will draw attention or get you defected.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
