hey gang,
my gtst has the a-lsd vspec diff. its shagged and basically single spins most of the time.
the slip light comes on and the electronic side appears to do its thing.
it has locked mech previously (burnout photos) so it did work at some stage.
its at a place being disected as we speak but i am not sure what to do.
he suggested a kaz centre to replaice it. has anyone been down a similar path?
can it be fixed? they arent sure if its viscous with pump or mech gears diff.
for simplicity i would rather keep it the same cogs and centre (but have it work)
can i just replace the inner cogs inside it (if thats whats dead)?
https://www.sau.com.au/forums/topic/128917-replacement-repair-of-vspec-diff/
  • Replies 68
Its easy enough for them to rip the center out and check if its visc or mech.
Another option if your not so keen on a clunking and bucking mech. (subjective) is a s/h GTR center, they are a mech clutch lsd but not as harsh as an aftermarket lsd, if I were to go down this route I would have it shimmed lightly to ensure its relatively tight. :ninja:
ah good point, didnt think of the gtr centre
so is it the same viscous centre as the stock gtr
and it just has elec controlled pump to turn it on?
cos ive looked underneath and its got the finned cover
then it has some hydraulic shit and a pump near the ass end
who wants a loose lsd?
tighten the bastard up :ninja: mine feels like a locker sometimes skipping the back wheels, thats where its at ...
paul you should be able to reco the gear thats in there although waiting for parts may be a pain in the ass, i havent heard anything about kaaz centers ... i think its kaaz anyways ... g/luck with whichever route u take ... cheaper option would to be reco i rekn, but i dunno ...
gonna get them to open it and find out whats inside
and then they will let me know whats busted
i could be a simple thing like the pump
or it could be the cogs are facked
either way im not buying a new centre bugger that
given that i wont be driving the car next year ish
not worth it. worst case if they cant reco it
ill get a 2nd hand gtr diff. i just found that auto diff is 4.3
could i change to that for some more punch
or is it too short
If its a visc. lsd then its just worn and really not much you can do to repair it.
If its a mech clutch type lsd then the clutchs are worn.
If a gear was busted it would be clunk, clunk, clunk. :rofl:
I don't know what the idea behind the active lsd's are, is it a form of traction control or does it lock the diff upon acceleration?
EDIT: All I could find was... # Active LSD system splits the torque between the rear wheels.
it looks at the abs sensors, when it detects wheel spin (slip light comes on) it turns on a hydraulic pump to make it lock. so it sounds like it just pumps in viscous fluid
ive had the fluid changed, that didnt help. had a look and poke around, traced the hydraulic lines and found a pump. unplugged it, started car and a-lsd fail would come on.
so it sounds like its the pump for it. the idea is to split torque (that i can think of) but as far as i can see it just does a diff lock. i cant see how it can throw power to one wheel but not the other.
Paul33
I will be watching this thread very very very very closely.
You know i'm very itnerested in the A-lsd, and it is very much an uncharted territory here on sau.
As far as i'm aware, it is a mechanical diff which is activated using the oil pump.
Have you tried bleeding the fluid? Some say that it's supposed to use attessa fluid - that is, nissan special pas fluid.
I would be very much interested to hear what happens.
gtr stock diff is a waste of money. People charge around 600 for the diff alone.
I was told that you still need the shafts and everythingbecause it has a different pattern.
Furthermore, the gtr diff is second hand. It'll probably be in the same condition as yours.
A brand new kaaz/nismo/cusco can be had for around the 1100 mark. Straight fit in.
I know which one i'd choose.
But the A-lsd is supposed to be superior to the standard gtr diff anyways, because it was in the v-spec.
So, I'd be interested to know how much it is to reco the v-spec unit.
had a chat with the diff centre place today. the diff is out of the car.
the centre is still in tact. they havent opened it yet.
the diff housing has an oil feed that goes in the right side, runs around, then pops up and relinks to the right side of the diff. so as you said, its an oil feed.
they are going to open the centre up and see whats inside and find outs busted.
he has said i can have a kaaz centre for 1500 then another 150 odd to swap it (if its fits) then the original 350 to put it all back in. so im looking at 2 grand. i said im not prepared to spend that. i was originally quoted 350 to open it up and find out whats wrong inside. he will proceed to open the centre (included in the price) and let me know whats the next step.
he said i can get a 2nd centre from somewhere else providing it fits but he cant guarantee it will be any better or work better than what i have. he also said it could die anytime as well being 2nd hand. if they change to a kaaz centre they will block off the oil feeds, which will most likely mean the pump wont work and ill have a-lsd errors on the dash all time (which would suck).
more to come when i check up on tuesday, after they've opened the centre
standard GTR diff is mechanical clutch plate type diff, NOT a viscous diff. I have NFI what an A/LSD is, but I would say it's mech too, with pressure from the pump altering the preload on the plates.
thanks bb. the a-lsd is the diff in the vspec gtr.
i think its the similar type but instead of mech locking it uses a pump to pump oil into the housing. it looks at the abs speed sensors to detect wheelspin on each wheel then locks when it see's wheelspin
heh paul, if thats the reason, well the pump highly likely isnt priming enough pressure into the diff housing/centre to lock the axles (sorry i dont understand how these diffs work properly)
but if thats the case, take off the pump, and see if it can flow a constant pressure, it may heat up and fail ...
just an idea ... :rofl:
yes paul you can change the ratios pretty easily in most diffs, not sure about yours ... depends what ratios are actually availible ... it will decrease top speed and fuel economy though, better low down rpm and torque tho ... will be hard to launch :P
interesting point gareth. i had the fluid changed some time ago, 8 months ish.
im not even sure what fluid was put in. ive got the guy disecting the centre and ill find out tuesday. it certainly could be pump and pressure related. how would i go about tetsting/checking
if you wanna know about the kaaz 1.5ways talk to Al, i think he just had his installed not that long ago. As for the Nismo 2 way, I have one, and love it >_< sure you get a bit of diff chatter on slow tight turns...but doesnt bother me. Makes the car very predictable an controlable when traction is lost.
but yeah, is a very expensive way to go, very glad mine had it fitted when I bought it 5 years ago
good luck Paul
hi all,
just got the report back from the diff place. there is nothing wrong with the diff. the center is fine, no damage, no metal shavings, no signs of fatigue or mechanical problems. the diff like gareth said (and they've realised now) is pressure controlled by an oil pump.
he said the next step i should do is test out the oil pump and oil feed. he said u could even just run an override switch to the oil pump power to make it lock on demand. so anyway ill get the car back tomorrow and the same 350 price. he said they will clean it up and change the oil and do some final testing but he said its likely the pump isnt providing enough pressure, or could have even ceased up. ill probably speak to dr drift and get him to help me debug whats wrong with the pump. an override switch would be ace
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
