also noticed that you must let it warm up and get some heat into the diff before trying to lock it and go sideways. if you dont it just single spins.
its only when the fluid is warm and been locking for a bit that its ready to lock. i tried a lock last night and it just single span for a good 10 seconds.
but that was with cold diff and fluid
  • Replies 68
yeah the diff place refitted it and flushed out the diff centre and cleaned it up.
they mentioned putting syntheic something orrather in it.
i dont know how to bleed it, but there is a bleed nipple right next to the pump. im not sure if its attessa fluid that you put it in, it makes sense to be attessa fluid. it wasnt a direct oil taste (i smelt and tasted it) but more like an lsd fluid, i guess.
There's no point cleaning the 'stuff' in the diff centre.
that is just your standard diff oil. If you just change that a couple of times, it'll be clean. I've done that on my car a couple times already.
The thing that is sitll puzzling me is the oil feed system - not the diff itself.
nah they did it anyway as they had it apart and were putting it back in. i didnt ask them to do that, was just part of the pull apart and diag. yeah it could just be standard diff oil, im not sure but that makes sense.
what is puzzling you about the oil feed system?
ill do some testing tonight, ill see how long i need the pump bofore the diff and fluid is warm, warm enough to make it lock. hopefully about a minute of driving with the pump on is enoguh to warm up the fluid
man that is a lot of effort to achieve a result that is almost as good as a stock GTR diff or aftermarket LSD. seems like this option may be more trouble than it's worth. :O
well some may think so, but for me i wasnt prepared to spend some cash on a new diff so im kinda stuck with what i've got. all in all, its a lot better
once ive got a pressure guage on the oil feed ill be happy and feel safe so that i can monitor pressure.
yeah for sure you did the right thing. I just mean it's a lot of complexity (on nissans part) for an end result that is about the same as a nice mech LSD.
yeah me and the guy who helped me hack it (bennett) were having the same discussion, we came up with
1) why is it so compicated
2) why was it such a special factory option
3) why an extra 5k (apparrently) ???
4) why not just a good mech diff ?
we couldnt see any logical reason why they made it how it is, a computer controlled oil pump to lock the diff.
why such expensive parts for a simple feature really, provide a good limited slip diff.
the thing that is still puzzling me and always has been is this:
New Attessa fluid isn't black. Every A-LSD car i've seen has black fluid - mine included.
How do you bleed it - I'm talking proper nissan manual pages.
And also, evidence of what fluid to use. not just I think it is powersteer.
No one on sau has been able to answer this yet.
I'm still ocnfused.
no idea. i could get some of the oil taken out and tested to see what fluid it is or i could just ask whoever changed it last what did they use.
also tonight, turned pump on warmed it up.
pump on, got pressure to higest (sensor goes off, and kills a-lsd)
take off, diff locks but i get EXTREME axle tramp
like violent. so its locking, but now i have suspension gayness
more testing and playing around. it doesnt seem that crash hot on locking when going sideways. and it also seems to be be much better when its warmer/hot. i did some reading and found some pages about the right fluid to use in the gtr 4wd system. i have a feeling ive got shit fluid in the resivour and pump so im going to change it to gtr 4wd stuff. more to come when i change the fluid
1. undo nipple next to the a-lsd pump
2. a bit of fluid trickles out
3. turn car on, left a-lsd pass diag
4. run pump manually
5. wait for trickling to finish
6. check that a-lsd resivour is empty
7. close off nipple
8. put in new castrol transfer max Z
9. top up to max line
10. put cap back on
11. go for a drive
12. experience correct active lsd locking operation
the diff operates like a brand new locking diff now.
it locks each time perfectly in computer mode and does prefect gliding.
no need for the manual switch anymore as it operates spot on with the a-lsd puter driving the show. i am amazed at how much of a difference that has made to my car.
it seems there was a big air pocket in the system and bleeding it has taken that out. im bleeding it again to cycle out the bad fluid. the fluid that came out was brown/orangey.
the new stuff is a new bluey/green. so ill flush the current mix out again and hopefully have a close as possible 100% fill of castrol transmax Z.
the gtr transfer case uses the transmax Z stuff which is actually automatic transmission fluid
I don't understand.
So you undo the nipple - won't air get in if only a little bit trickles out?
how do you run the pump manually?
So does it feel much much tighter after bleeding the system?
Where did you find out from that the system uses that trnasmax z and where did you find the procedure the bleed it? I've looked in all the service manuals.
The transmax z is my secret. The getrag in the R34 GTR uses the same oil as the main gearbox oil - and the getrag in the R34 is for all intesive pruposes the same gearbox as used in the TT Supra - and the Supra people over in the US were kind enough to tell us that the Toyota V106 and the Nissan what ever it is - is just Castrol Transmax Z rebadged.
yeah the service manuals dont cover the vspec system at all and how to blee d and diag it. since more testing i am back to intermittent locking agian. some times it locks, sometimes it doesnt. the first time i bled it and put new fluid in, it was ace and locked perfectly. now that ive redone it again its intermittent. so im bleeding it incorrectl. you can run the pump by either turning to ON (without starting) and leti it prime or i can turn my switch on which runs 12v direct to the pump.
Luckily I didni't try and bleed it. I'm so excited and it's difficult to wait.
I think the problem is that when you open the nozzle and the fluid is only randomly trickling out, air can get back in.
On the attessa systems, there's a bleeder plug, which you have to undo. After you undo it, once you open the nozzle, the pump runs and pumps the fluid out.
The A-LSD must have somethign like this.
I'm still tryign to find a manual that does haev the system. I only ahve the r33 normal one and the r32 gtr manual.
If someone has the r33 gtr vspec manual or r34 manual, that'd be ace.
by all means wait until i completely sort it out and get it working 100%
i checked the resivour this morning and its well past max. approx 5-6cms over max so the fluid is way out of whakc. ill bleed more out today when i get home. yeah a mate said there should be a nipple on the diff housing somewhere but there isnt and the fast diagrams dont show one either. only one nipple below the resivour, next to the pump
ive got r32 gtr workshop, r33 workshop and r34 workshop
none of them cover vspec or active lsd
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
