WRECKING R32 2 DOOR
ITEM/S: Rear Bar - $100
Taillights - $110 each or $200 pair
Bar support - $100
Front Indicators - $120 pair
Dash surround - $150
Rear Bumber support - $100
Dash - $100
Head lights - $80 each
Bonnet - $100
Front Gaurds - $80 each
Rear Seat - $100
Mirrors - $140 pair
Silvia Sr20 Cross member - $100
Doors + Trims - Offers
Dash Cluster - $120
all skyline parts are off a white 32 2 door, reasonable offers considered. located in karana downs, brisbane/ipswich, PM me or call 0438 113 248 and ask for tim, cheers
https://www.sau.com.au/forums/topic/129059-wrecking-white-r32-2-door/
*edit*
WRECKING R32 2 DOOR
Bar support - $100
Dash - $100
Bonnet - $100
Rear Seat - $100
Mirrors - $140 pair
Dash Cluster - $120
Edited by Andyn
Hey man,
I need little pieces if you still got em..
Theres a piece around the ignition, just a plastic thing... i need that
and
On the rear view mirror theres a plastic surround at the top.. need that too.
let me know if you got em. thanks
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
    • So 10/10 times that code is coil packs? I mean if that's the case ill drop the $400USD or so to replace them. I didn't know these cars threw codes before the issue became an issue.
