Hey guys,
Anyone got a spare set of DB1170-ULT hanging around?
(Or similar pad of the same performance or better)
Best price I've found is $118 in Chatswood but some peeps can get em cheaper???
Someone PM'd a year ago with a spare set but i lost their details ( so if you're still around, give me a yell)
Thanks.
Birnie
https://www.sau.com.au/forums/topic/129130-bendix-ultimate-r33-db1170/
Hey guys,
Thanks.
Birnie
got mine from repco for $100 a set
then justin911 went to his local repco, told him that my repco did em for $100, and they gave em to him for $90 a set lol...
cost is about $85 a set according to their computer, so dont expect any lower than $90ish
Which Repco's were they?
I'd be happy with $100
My repco was hoppers crossing, justin went to morabbin
But any repco should do the same...
basically i went in, asked if they had the pads (gave them part numbers)
he asked me if id gotten prices anywhere else, and I had just come from autobarn...they quoted me about $130 for the front, $120 for the rear, and when i told repco that, he said...RRP is $145.....so....$100 a set?
hehe I was expecting him to match autobarn, but he went 1 better.
Then Justin went to his and told them that my repco did them for $100 a set...so his decided they'd beat mine and do em for $90.
i have got these brakes on my car at the moment
and they are pretty good
the guy at the shop told me that they can be a bit dusty, but havent noticed it.
disc pads
db 1170 ec/f
Model: nissan 300zx, skyline gtr/ 90-on
Non asbestos
http://www.autobrakeservice.com.au/our_loc...php?store_id=23
If i remember correctly i got them ffrom here, i only got the ones for the front, but they were fairly cheap.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
