a few updated pics...motor is in car and broken in, tuning is almost complete.
got a few rich spots to sort out but other than that its almost there.
kinda sucks but the brake master died (was leaking externaly) so i just got done replacing that...oh well only was 30$ at the junkyard when i got it.
what it looks like from the drivers seat: defi gauges (oil pressure, water temp, egt) and greddy e01/wideband
and a few exterior shots, first time the car has been washed in 6 months.
  • Replies 66
Posted Images
Very cool rb20 build up. Don't want to sound like a critic here but what about a heat shield over that exhaust manifold. It will get stinking hot!
Keep us posted on the dyno/et results - love to see them.
Cheers
Cheers
It ceramic coated so heat should be kept to a managable level i would think.
while the manifold is coated it still gets a touch toasty...thinking of fabbing up a sheet metal heatsheild, shouldnt be too hard i would think.
finished the intake pipe today, not terribly pretty but it does indeed work and seems to do its job of keeping the intake charge cooler, however due to the exhaust manifold and wastegate the charge pipe on the hotside and the intake tube catch quite a bit of heat even tho they are pretty far away from the manifold.
im thinking that the external gate isnt dumped far enough out of the engine bay so im proly gonna extend the dump tube a bit...
HOWEVER...from this latest run down the road car seems to pull quite nicely and has good afrs to redline, pulls so hard its actualy kinda scary because of how fast it gets going.
gonna try for vids this weekend...
Edited by carl h
Hi Carl , yep all looks good .
Phoenix wants an upper cut because that "GT30R" has a version of Garretts T3 exhaust housing on it . Don't know if you wanted it that way but either Garrets or HKS's GT30 housings will work better . HKS's , intended for the GT3037 - esentially the same thing , housings are more compact than Garretts and would place the turbo in a better position with regard to the engine mounting bracket . They were designed to work in kit form with that manifold on RB20/25's .
Cheers A .
right right, whatever turbine housing that got shipped with my 30r isnt the gt spec bit, it fits but its certinaly not the gt one as the gt one has 3" outlet while mine only has a 2.5"...this may be contribuiting to some of the weird spool charcteristics that im getting from this turbo.
it kind of irritates me that this happened but it was too late before i noticed.
manifold clearance is fine really, more space than i had originaly expected while more would be nice this will for now.
center section is indeed a 30r center section as is the compressor cover, but like you pointed out the exhaust housing is a touch strange, hopefuly anyone who goes after a 30r in the future will grab the right one.
Cheers A .
Yes the flange on the exit side of the HKS is slightly more compact than the Garrett one but then compact is good in most engine bays . Being in the US means that you could probably track down a suitable HKS housing from one of the HKS dealers - can buy separate . The T3 housing will have issues with the GT30 turbine because it was designed many years ago to suit low tip height T3 turbines . The turbine and housing type really are a matching set designed to work with each other .
Cheers A .
Very nice to see carl, good work will be intresting to see how it goes when finished .You made 6rwkw more than me with my old car, had stock bottom end too (60,000k's on it ) b4 I bent it . Doing the same thing to the new car but some things will change I like some of your work and gives me good ideas for mine,Mods are nearly the same but mine's still a couple months of only just started to rebuild the car
Mods Are
Airas forged pistons + 40thou
balanced and blue printed bottom end
arp bottom and head stud bolts
tomei rod bolts
tomei metal head gasket
tomei oil restrictors ( I agree with you 2 is better than one no chance's )
Resized rods shot peened and linished
N1 oil pump
N1 water pump
Crank collar
Nismo bearings
Top end
Ported and polished head
Hks cams
Hks cam gears
gtr valve springs
1 mm oversized valves
Hks exhaust manifold ( same as your's )
Hks external waste gate (again same as yours)
Garrett Gt3040R turbo
Sard 550cc injectors
Sard fuel pressure regulator
Havn't decided on a plenum yet probably go with the plazma man 1
Engine manegment is taken care of by haltec E11 v2
What engine manegment are you using and what size injectors
anxiously waiting for your results
Cheers Peter
I can't believe how much space you have in the s14 engine bay
It's a bit tighter in the r32 engine bay :O I had to move the power steering reservoir to fit the compressor outlet pipe.
ledgend01 - thanks, yours sounds to be pretty evil when done too. im currently running an rb25det power fc and 720cc injectors, i found using 550cc injectors on the old setup it was going over the 80% duty cycle (not by much mind you...) but it was enough to make me think of upgrading.
when one of my supra buddies upgraded to 1kcc injectors i sold mine for 200$ and picked up his for 200$ so it was a straight trade really...
hopefuly this weekend we will get some video.
tune is all hammered out 13:1 from 3.5-4.2k(spool up,no more than 10psi) then from 4.2-5k it goes to 12:1 then from 5-8.5k its a solid 11.5:1 ratio.
she seems to go quitenicely and on base boost scared me a few times as 1st and 2nd gears have questionable traction...
and yes, the s14 engine bay is HUGE compared to the skyline or the s13 engine bay (which the motor was in at one point).
having a few problems with spark being blown out, so limited to 16psi right now...new plugs and regap to .8mm should fix the problem.
for your enjoyment...
http://www.3rdgearvtec.net/Andys%20Videos/Carls%20Vidz/
you will need the divx codec to watch these www.divx.com
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
