  • Replies 422
Posted Images
Are you running a Pod Jazza? Would most likely explain the temps, used air from the radiator was probably being passing over; either that or the temp sensor was slightly placed incorrect.
With my CAI I see temps pretty much spot on the AT temp. Within a degree or two.
No I'm running the stock airbox actually, just with an APEXI panel filter. I must admit I was surprised that the reading was so high, though the fan could have actually been directing air around in the engine bay before heading into the CAI (I noticed the fan was completely missing the airbox as well as the intercooler), not to mention the whole car was hot from only just being driven & sitting out in the sun for 15 minutes.
There was also clearly heat issues with the smic as it did drop 7kw on the second run (you could see on the graph the torque dropping off right through the rev range. even though the boost creeps up a bit), though I'd be curious to see what the IT temp was on the second run.
Just out of curiousity how much power correction would you say there was Cubes? I do still very much agree with the dyno reading as acceleration at the top end for my car is far more explosive than it used to be with my old split dump (not as good a design & it cracked).
Thanks for letting me in in the traffic this morning by the way DriftR_33, made it to work with only 1 minute spare thanks to the fire at Jaycar
Edited by JazzaR33
If assuming that Dyno Dynamics use SAE J1349 reference conditions, the reference temperature is 25C. If your IT was 40C, the correction would be roughly +3%. Conversly if the IT was 10C, the correction would be -3%.
Hmm if this is so, then my actual reading was roughly 164kW before power correction, which is 6kw less again than even my second run came up with.
Hmmm, would be interested to know what others were getting on their IT readings now.
My IT was 37.
What I wanna know is what the reference BP (barometric pressure) units are that DD are using. If its kpa, then I would assume that a BP of 101.1 would have a negative correction on all our readings as the SAE reference is 98.8kpa.
Might shoot Dyno Dynamics an email...
My IT was 37.
try and find my extra 20kw that i lost :(
my extra bits are
BP: 101.3 RH: 60 AT:25 IT:39 RR:013 TN:3.454
Interesting.... re the night time.
Would be good to go somewhere different also..
Blackwood auto and dyno has a good setup; from memory I remember they had windows that you could stand against and see the car running up.
There's also Hitech dyno.
Sorry Madaz can't say much from your Shootout parameters. Either your car has really lost power or the parameters from your last reading where whacky beacuse the current run seem OK to me right now.
And yeah a night time dyno would be sweet. But even during summer where its mid to high 20s over night, its still gonna be friggin hot!
Btw Cubes when I was in the cell I was sweatin in there? It seemed pretty hot. Or maybe because of all you onlookers expecting 1000rwkw. lol.
try and find my extra 20kw that i lost :D
I found it......... I found it.......... It came to my car, i was reading 18kw more than last time on the same dyno WITHOUT touching a thing! :)
As for the night time dyno thingo........ would either have to speak to residents around the area or find a dyno in a industrial area, cos i don't think they would be too happy!
I found it......... I found it.......... It came to my car, i was reading 18kw more than last time on the same dyno WITHOUT touching a thing! :laugh:
Wilall Industries... Might wanna speak to M Donnan
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
