Hopefully I get my Skyline (R33 GTS-T) back this week, it's dragged on long enough already, but anywho, was just wondering whats the best way to run the engine in? It's had a complete Forged engine rebuild
Hills? Highway? What speeds? etc..
https://www.sau.com.au/forums/topic/129959-running-in-engine/
bed the rings on the dyno.
Then tune it up. Its pretty basic.
The whole "1000km this" "5000km that" "light load" "heavy load" etc etc is all rubbish.
I've had one motor bed on the dyno, and drove out the door on virtually the full tune.
Will be doing the same for my RB26 :(
Will be doing the same for my RB26 :thumbsup:
I get diffrent opinions from people, thats why I wanted to see what other people thought FATGTS-R and Do-Luck.
But, anyways we're going to bed the rings on the Dyno, and "run it in" over 2000KM. Just wanted other people's opinion, is 2000KM long enough, or too short?
Thanks for the responses.
Whered you get the rebuild done in brisbane?
By a bloke named Rob at 101 in Slacks Creek, he done cars such as 'Drag Me' etc. Good service, but dam they take a very long time, they've had my car for two months now and it's still not finished.
I read an article on this last night as I will be running one in soon as well. The concept is to allow all the surfaces that will be rubbing each other to match eachother so they can cope throught he whole temperature range. So yes this does mean it's a good idea to drive like a sissy from the start.
Throughout the process (2000km your mechanic said, but 1000 really should be tops these days), you gradually drive harder & harder. They should also be setting the rev limiter to about 4000rpm for you as well.
OK I am hungover today & I know I can word it better than I have but hopefully it makes some sense.
Nismoid you are very brave to leave the workshop on gate. :no:
I guess thats ok aslong as its all done properly though, ive got a friend with a car there, blue 32 with the lot
Can you post a list of the things done and an approx price?
Edited by knore
Nismoid you are very brave to leave the workshop on gate. :(
Hell, if the builder will warranty the engine on the "run it in hard and it'll go hard" theory then why not. Any failure goes back on him!
If I was wearing the risk myself though, I'd take it easy at first and gradually get into it after a few clicks. That way at least you have some recourse that you didn't even flog it and it died, so it can't be your fault.
Not really. Im dealing with one of the more knowledgeable people in the business.
When you trust someone's word, i dont see it as a risk. We ran it @ 75-80% power for around a week at the most.
Going from 200rwkw to near 300rwkw i was happy to have it detuned a tad.
The motor was apart semi-recently and it was A-OK internally. Not a thing wrong with it after over 7,000km's of some serious work from day one.
So there is no doubt at all in my mind that the method works and ill have my RB26 done the same way. Bed it on the dyno and just tune it up.
There is no warranty on performance anyway. Your kidding yourself you think there is :)
Hence the 'If' - if I just paid several grand for a new engine I'd be babying it!! :(
If I earnt enough that I didn't care if it popped again yeah I'd give it arseholes out of the box :)
bearing clearances opening up, things settling in over a few heat cycles, any microscopic high points on bearings/cams/rings being worn smooth, etc..
new engines are supposed to be pretty tight, forcing them to make a lot of power straight up seems a bit mean :wave:
but most of the above is probably done in the first 50km, after that it makes less and less difference!
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
