Example
Car A - V8 N/A. IT of say... 40 degrees according to DD Testing rules
Car B - Turbo/Intercooler 6. IT of also 40 degrees according to DD Testing rules
Which car gets the more unrealistic reading? Car B.
Why? Lets see if people can workout why.
  • Like 1
And we have a winner... never takes long for someone with half an idea :(
40 degrees for the V8, the turbo car is reading 40degrees.
However then the I/C is doing its work, so the figure is incorrectly having adjustments on it for the turbo car.
Hence i dont agree with DD methodology. It works for NA no problem, not turbos
From what I was told, a shootout run should have the inlet temp sensor placed inside the inlet tract just before the throttle body i.e after any intercoolers etc but this is obviously going to be more time consuming on a dyno day for example and never is adhered to.
Depending on where you put the inlet temp sensor, when i tune my car we leave the sensor hanging in ambient temp, not in front of the pod filter as if the motor is sucking hot air i would like to know about it on the dyno so i can rectify the problem. This was my intercooler is never going to cool below ambient, so there would be no problems.
Ok, I have spoken to a few people about this, including a Dyno Dynamics Shootout operator (not the one who tested the car). I have trouble believing that a stock R33 with only turbo-back exhaust and pod filter can make 178rwkw, but noone seems to be able to give me a straight answer.
I can't post my dyno sheet so I guess, it doesn't really matter. I would like to try and understand how a dyno works, so I can then work out how accurate power figures are when you see dyno print outs.
Edited by Quinny
And we have a winner... never takes long for someone with half an idea :P
Thus the reason for;
Shootout Mode 6
Shootout Mode 6F
Shootout Mode 8
Shootout Mode 8F
There are different correction tables/values for forced induction cars.
Thought this was fairly apparent.
Adrian
Come on, your not meant to post that :rofl:
How does a dyno know the efficiency of a intercooler setup of any given vehicle? Whats it based upon?
I'd be extremely interested to know how they have a correction table that can take into account a heatsoaked system, or adversly an extremely efficient one.
with the tyre thing...the blokes at mercury told us to put some skinny ass tyres on there to get a higher hp reading, we had 255 semi slicks at the time.
Edited by r33_racer
I fail to see how a heat-soaked system (or otherwise) will affect the power being produced at the rear wheels any differently to how that same heat-soaked system would at the track?!?
Shootout mode was designed to make COMPARISONS more accurate.
So the question of whether intercooler efficiency can be measured on a chassis dyno is moot. It is a more accurate representation of the RELATIVE performance of different types of vehicles on a chassis dyno.
Nothing more, nothing less.
And if anyone has a problem with DD dynos or chassis dynos in general, remember the lowly video cassette tape. Beta is said to be a technically superior system but the popular standard won out in the end. Is it a good thing? Is it a bad thing?
Who cares. It's the standard that people use.
Deal with it.
Are we talking about the track? I dont recall that being so.
Its not a moot point at all. Its extremely relevant.
If you have corrections being applied, based one some "software" thinking there is much lower IT temp than is actually being supplied based on some corrections table within the software itself... then how it is gone to be anywhere near accurate? because it isnt.
Thought i'd save you the heartache of answering that one cause i already know the answer.
Setting up a performance car is all about the package.
Inlet air temp compensation should not be taking in to account.
Ambient yes..
Why should the pod bloke receive a slightly inflated figure when at the strip the conditions are not 'equaled' via an IT temp sensor.
Tyre sizes might give you a bigger hp reading or not
its EXACTLY THE SAME AT THE TRACK
the smaller the tyre the more revs you have in the top end
the bigger the less
Thats when you change gear ratios ETC
and do you know gear ratios also make a difference on a dyno As do on the track
Most DYNO QUEEN cars Run a 3.11 or so gear ratio to help load the dyno more giving a Incorrect reading.
99% of our skylines run a 4.11 4.36 gear and same as most toranas and v8`s
The Shootout mode was designed For COMPARSION from dyno to dyno as mentioned early.
In order for you to be happy then
RUN A AIR TEMP SENSOR JUST AFTER YOUR THROTTLE BODY and get the temperature there and match it on the air temp sensor on the dyno.
What about cars with nitrous and cooler fuel
do you wanna take this into account as well
Nitrous i think is around -50 or so when entered into the manifold and heats up as it goes it
what do you do there
Anyways like i said
TUNING TOOL
That photo SUITs ya
Which I think is a load of crap... Its incorrect for one car that has been setup poorly to have its dyno reading inflated due to greater IAT's. It should be based on amb that places a small correction on the run; close the bonnet do the power run and thats it.
I'm not saying that towards you, its towards dyno dynamics. As what are you to dyno dynamics apart from using the product? sfa. :(
However, can you see my point of view?
I'm very aware that a dyno is a tuning tool and power figures should be taken with a pinch of salt since right back when I had my first dyno run on an old analogue needle swinging pice of crap.. (~9yrs ago)
My view is that if a car is making up close to 200rwkw well its getting up there and most definitely not making a stock 125rwkw.
+- ~20-30rwkw, outside of that and I tend to start thinking some one is playing funny buggers.
MR331307, please don't get personal towards other forum members. Functional discussions get us all places, dysfunctional gets us no where.
He is just trying to have a dig at me with something he thinks he knows heaps about... but cant even address the simple issues surrounding it all.
But if its a tuning tool, i dont see why it requires such indepth explainations such as post #1... :P
All's fair in love and war.
And its me in my avatar :)
Come over for a DECA weekend, we'll show ya how to drink some booze :(
    • See if you can thermal epoxy a heatsink or two onto it?
    • The other problem was one of those "oh shit we are going to die moments". Basically the high spec Q50s have a full electric steering rack, and the povo ones had a regular hydraulic rack with an electric pump.  So couple of laps into session 5 as I came into turn 2 (big run off now, happily), the dash turned into a christmas tree and the steering became super heavy and I went well off. I assumed it was a tyre failure so limped to the pits, but everything was OK. But....the master warning light was still on so I checked the DTCs and saw – C13E6 “Heat Protection”. Yes, that bloody steering rack computer sitting where the oil cooler should be has its own sensors and error logic, and decided I was using the steering wheel too much. I really appreciated the helpful information in the manual (my bold) POSSIBLE CAUSE • Continuing the overloading steering (Sports driving in the circuit etc,) “DATA MONITOR” >> “C/M TEMPERATURE”. The rise of steering force motor internal temperature caused the protection function to operate. This is not a system malfunction. INSPECTION END So, basically the electric motor in the steering rack got to 150c, and it decided to shut down without warning for my safety. Didn't feel safe. Short term I'll see if I can duct some air to that motor (the engine bay is sealed pretty tight). Long term, depending on how often this happens, I'll look into swapping the povo spec electric/hydraulic rack in. While the rack should be fine the power supply to the pump will be a pain and might be best to deal with it when I add a PDM.
    • And finally, 2 problems I really need to sort.  Firstly as Matt said the auto trans is not happy as it gets hot - I couldn't log the temps but the gauge showed 90o. On the first day I took it out back in Feb, because the coolant was getting hot I never got to any auto trans issues; but on this day by late session 3 and then really clearly in 4 and 5 as it got hotter it just would not shift up. You can hear the issue really clearly at 12:55 and 16:20 on the vid. So the good news is, literally this week Ecutek finally released tuning for the jatco 7 speed. I'll have a chat to Racebox and see what they can do electrically to keep it cooler and to get the gears, if anything. That will likely take some R&D and can only really happen on track as it never gets even warm with road use. I've also picked up some eye wateringly expensive Redline D6 ATF to try, it had the highest viscosity I could find at 100o so we will see if that helps (just waiting for some oil pan gaskets so I can change it properly). If neither of those work I need to remove the coolant/trans interwarmer and the radiator cooler and go to an external cooler....somewhere.....(goodbye washer reservoir?), and if that fails give up on this mad idea and wait for Nissan to release the manual 400R
    • So, what else.... Power. I don't know what it is making because I haven't done a post tune dyno run yet; I will when I get a chance. It was 240rwkw dead stock. Conclusion from the day....it does not need a single kw more until I sort some other stuff. It comes on so hard that I could hear the twin N1 turbos on the R32 crying, and I just can't use what it has around a tight track with the current setup. Brakes. They are perfect. Hit them hard all day and they never felt like having an issue; you can see in the video we were making ground on much lighter cars on better tyres under brakes. They are standard (red sport) calipers, standard size discs in DBA5000 2 piece, Winmax pads and Motul RBF600 fluid, all from Matty at Racebrakes Sydney. Keeping in mind the car is more powerful than my R32 and weighs 1780, he clearly knows his shit. Suspension. This is one of the first areas I need to change. It has electronically controlled dampers from factory, but everything is just way too soft for track work even on the hardest setting (it is nice when hustling on country roads though). In particular it rolls into oversteer mid corner and pitches too much under hard braking so it becomes unstable eg in the turn 1 kink I need to brake early, turn through the kink then brake again so I don't pirouette like an AE86. I need to get some decent shocks with matched springs and sway bars ASAP, even if it is just a v1 setup until I work out a proper race/rally setup later. Tyres. I am running Yoko A052 in 235/45/18 all round, because that was what I could get in approximately the right height on wheels I had in the shed (Rays/Nismo 18x8 off the old Leaf actually!). As track tyres they are pretty poor; I note GTSBoy recently posted a porker comparo video including them where they were about the same as AD09.....that is nothing like a top line track tyre. I'll start getting that sorted but realistically I should get proper sized wheels first (likely 9.5 +38 front and 11 +55 at the rear, so a custom order, and I can't rotate them like the R32), then work out what the best tyre option is. BTW on that, Targa Tas had gone to road tyres instead of semi slicks now so that is a whole other world of choices to sort. Diff. This is the other thing that urgently needs to be addressed. It left massive 1s out of the fish hook all day, even when I was trying not too (you can also hear it reving on the video, and see the RPM rising too fast compared to speed in the data). It has an open diff that Infiniti optimistically called a B-LSD for "Brake Limited Slip Diff". It does good straight line standing start 11s but it is woeful on the track. Nismo seem to make a 2 way for it.
    • Also, I logged some data from the ECU for each session (mostly oil pressures and various temps, but also speed, revs etc, can't believe I forgot accelerator position). The Ecutek data loads nicely to datazap, I got good data from sessions 2, 3 and 4: https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-2?log=0&data=7 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-3?log=0&data=6 https://datazap.me/u/duncanhandleyhgeconsultingcomau/250813-wakefield-session-4?log=0&data=6 Each session is cut into 3 files but loaded together, you can change between them in the top left. As the test sessions are mostly about the car, not me, I basically start by checking the oil pressure (good, or at least consistent all day). These have an electrically controlled oil pump which targets 25psi(!) at low load and 50 at high. I'm running a much thicker oil than recommended by nissan (they said 0w20, I'm running 10w40) so its a little higher. The main thing is that it doesn't drop too far, eg in the long left hand fish hook, or under brakes so I know I'm not getting oil surge. Good start. Then Oil and Coolant temp, plus intercooler and intake temps, like this: Keeping in mind ambient was about 5o at session 2, I'd say the oil temp is good. The coolant temp as OK but a big worry for hot days (it was getting to 110 back in Feb when it was 35o) so I need to keep addressing that. The water to air intercooler is working totally backwards where we get 5o air in the intake, squish/warm it in the turbos (unknown temp) then run it through the intercoolers which are say 65o max in this case, then the result is 20o air into the engine......the day was too atypical to draw a conclusion on that I think, in the united states of freedom they do a lot of upsizing the intercooler and heat exchanger cores to get those temps down but they were OK this time. The other interesting (but not concerning) part for me was the turbo speed vs boost graph: I circled an example from the main straight. With the tune boost peaks at around 18psi but it deliberately drops to about 14psi at redline because the turbos are tiny - they choke at high revs and just create more heat than power if you run them hard all the way. But you can also see the turbo speed at the same time; it raises from about 180,000rpm to 210,000rpm which the boost falls....imagine the turbine speed if they held 18psi to redline. The wastegates are electrically controlled so there is a heap of logic about boost target, actual boost, delta etc etc but it all seems to work well
