  • 1 month later...
Was about time i got around to making a CAI box for the car ... and had a couple of hour spare today ...
went upto the local mitre 10 and bought a sheet of 600 x 600 aluminium, this was about twice what i actually needed. They were out of pop rivet guns, so had to use nuts and bolts with spring washers :P
anyway, roughly measured what i needed, cut out a cardboard box to the rough size, tried it, trimmed it a bit, repeated this a few times, and came up with a good size, transposed this onto the ali sheet, and cut out, the top was just made by roughly cutting out what i needed, then placing it on top of the vertical sheet now in the car, and drew around it with a marker pen, cut it out, then cut lots of small cuts along the edge so it could fold over and bolt upto the ali part easily.
Bent the lip of the top, drilled holes, bolted up, and sprayed with some heat resistant paint, slotted it all in place, and used the headlight mount to bolt it down ..
i cut some fuel hose long its axis and slotted it along the bottom, this is just to stop the ali sheet scratching the inner wheel arch.
The bottom of the vertical part os bent in slightly to avoid the pipe going down into the FMIC from the turbo. As i have an FMIC the pipe that the std intercooler would return to is not there, and so is basically a 2.8" hole to behind the indicators (its s series 2) so i have a nice cool air feed to the inside the box ..
see pics below
www.host32.com/line/cai/DSC01946.JPG
www.host32.com/line/cai/DSC01947.JPG
www.host32.com/line/cai/DSC01949.JPG
www.host32.com/line/cai/DSC01950.JPG
www.host32.com/line/cai/DSC01951.JPG
This last pic is a view from the front nearside, behind the indicators (cameria is in the hole under the indicator) you can see the hole that feeds the cai.
all in all took about 3 hours, will get around to putting a window in the top at some point when i can be arsed.
No idea if its made any difference to performance, but it certainly cant hurt ...
roll on the 550cc inj and pfc tune
  • 3 months later...
Basically it will be a box extending from just under the guard lip on the right covering all the filter and cooler piping, and drop straight to the floor next to cooler piping and will be all polsiehd and look fancy etc aswell as serving its purpose. Everyone who is interested please PM me and tell me, as i have to do these in my free time at work (lunch time, friday arvo's) so i don't want to be wasting time. It will probably work out around $80 each plus shipping? Sound good? Polished alloy, ready to fit... Let me kno, i'll do mine in the next few days n post pics then you can see. :P
Hi YBSLO4, just wondering how you ended up going with the new box?
Wouldn't mind seeing how it looks and if you think it made things better.
PM me if you like.
Cheers!
original airbox was too restrictive with the panel filter.
installed a pod filter a while ago to my NA it was an improvement, but it was just sitting there and seemed very sluggish due to the heat from the engine.
I then decided to make a heatshield to try and make the most of it.
template was made with cardboard - made about 3-4 of these, continously trial fitting.
transferred the cardboard template onto aluminum sheeting
mounted brackets to hold the sheeting in place
insulation foil on both sides to keep engine heat away from pod.
I have yet to do a temperature check, but after a fairly spirited drive for 20mins, and placing hands on either side of the heatshield - a large difference in temperature was apparent.
This was done on a under ~$30 budget - i took my time in doing it - but can be done in a few hours.
End Result:
  • 3 weeks later...
Hi Guys,
I currently planning on making a cold air induction system for my 32 gtr.
I envisaged buying a standard air intake snorkel (as my car came without one) feeding that into a cold air box as well as trying to fabricate some sort of wide tubing running into a fiberglass funnel to fit the box through the awkward oval hole shown below:
I can only find R32 gtst snorkels so how do they differ, if at all, and does anyone know if an the gtst snorkel will fit the GTR mounting holes etc?
Also, I’d imagine that cutting sheet metal is a BIG NO NO incase of defects etc, though the hole shown is a tad small, what do you guys think.. and what are other peoples methods of feeding air in without cutting metal or drilling holes??
Help appreciated, cheers.
  • 1 month later...
http://www.skylinesaustralia.com/forums/sh...ead.php?t=74355
refer here for more details...
dyno charts show before and after effects and a full write up on what changes i felt
in driveability.
Hi mate,
Just a question, I know you said you used aluminum sheeting, it looks quiet thick though, is that all you used? I'm just getting ideas at the moment.
Cheers!
its an aluminum sheet, then on both sides stuck with a foam layered foil type thing (courtesy of 51jay) - can be picked up @ clark rubber or something similar.
does the job, keeps the hot air out, and limited to the heat shield.
engine bay || foil/foam || aluminum sheet || foam/foil || pod filter
^^^^^layers are pretty much like this ^^^^^
I've used 2mm Ally but I think the benefit comes not from the aluminium but the foam foil layer.
Eug - to take your example, I have this setup :
engine bay || foil/foam || aluminum sheet || pod filter
without a scond layer or foam/foil and according to my temp gauges, it keeps the intake temp within 2-3 degrees on ambient temp when cruising.
Thanks mate!
I'm in the process now of cutting out a template and getting the right fit.
Thanks again!
  • 4 months later...
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
