how much boost?
I give it 2 weeks before it throws a rod :no:
It wont throw a rod unless you run big boost. I rekon 14 psi and youll be fine. Just get it tuned properly. That said, I dont know about the strength of the RB25DE bottom end, but I cant imagine it being weaker than NA SRs or CAs which can handle 14 psi on stock bottom end.
Go it!!!!
https://www.sau.com.au/forums/topic/130071-turbo-rate-it/#findComment-2406187
yeah i know the turbo can put out 30psi but give it time and ill work my engine to support my turbo...
this is only the start of things
and yeh i was just wanting someones opinion on my turbo...
do u think ill get much lag ect....
https://www.sau.com.au/forums/topic/130071-turbo-rate-it/#findComment-2406219
RB25 front housing and core - ar63 rear housing - 30psi thrust bearing - gt30 front compwheel
this good setup?
I take it you meant 360 degree thrust bearing?
If so, you are talking about a plain-bearing cartridge? Not going into the whole plain bearing / BB debate - been done to death. I'm not against plain bearings, but I did go with a BB cartridge upgrade.
When you say GT30 impeller, are you aware there is a range of trim sizes available? Which one? Nismoid's question about a compressor map is justifiable - read the literature that Garrett put out about them. The maths is not that hard either - you do need to know what your power target and intended delivery is.
Cubes is also right about the hot side being generally the limiting factor - it has to be able to flow what the cold side is stuffing in, but also to drive the cold side efficiently.
I don't have any probs with your choice, just a matter of knowing what you want it to do. FWIW, The Mafia and Jmac have both used a similar cartridge to yours for upgrade. Their posts seem to indicate satisfaction, even if others disagreed at times. Do a search and see for yourself.
I believe the RB25DE runs 10:1 compression. That should point out the immediate limitation of your intended match: any significant boost will likely lead to an early failure. Otherwise use a small-ish turbo and get it to crank out significantly more torque than the N/A engine. Much the same as Nissan did with the DET. Might actually be cheaper and just as effective to buy/install a DET engine in that case.
cheers
https://www.sau.com.au/forums/topic/130071-turbo-rate-it/#findComment-2406608
People are safely running 14 psi through the DE bottom ends on turbos of similar size down in Melbourne. Making 260rwkw. I have not seen it, however, but this is what I was told. Running more than this would be detrimental to your engine's health. That is also assuming the bottom end is not already "TIRED".
I don't think you will reach that hp figure but good luck with it anyway.
https://www.sau.com.au/forums/topic/130071-turbo-rate-it/#findComment-2406640
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
