how much boost?
I give it 2 weeks before it throws a rod :no:
It wont throw a rod unless you run big boost. I rekon 14 psi and youll be fine. Just get it tuned properly. That said, I dont know about the strength of the RB25DE bottom end, but I cant imagine it being weaker than NA SRs or CAs which can handle 14 psi on stock bottom end.
Go it!!!!
https://www.sau.com.au/forums/topic/130071-turbo-rate-it/#findComment-2406187
yeah i know the turbo can put out 30psi but give it time and ill work my engine to support my turbo...
this is only the start of things
and yeh i was just wanting someones opinion on my turbo...
do u think ill get much lag ect....
https://www.sau.com.au/forums/topic/130071-turbo-rate-it/#findComment-2406219
RB25 front housing and core - ar63 rear housing - 30psi thrust bearing - gt30 front compwheel
this good setup?
I take it you meant 360 degree thrust bearing?
If so, you are talking about a plain-bearing cartridge? Not going into the whole plain bearing / BB debate - been done to death. I'm not against plain bearings, but I did go with a BB cartridge upgrade.
When you say GT30 impeller, are you aware there is a range of trim sizes available? Which one? Nismoid's question about a compressor map is justifiable - read the literature that Garrett put out about them. The maths is not that hard either - you do need to know what your power target and intended delivery is.
Cubes is also right about the hot side being generally the limiting factor - it has to be able to flow what the cold side is stuffing in, but also to drive the cold side efficiently.
I don't have any probs with your choice, just a matter of knowing what you want it to do. FWIW, The Mafia and Jmac have both used a similar cartridge to yours for upgrade. Their posts seem to indicate satisfaction, even if others disagreed at times. Do a search and see for yourself.
I believe the RB25DE runs 10:1 compression. That should point out the immediate limitation of your intended match: any significant boost will likely lead to an early failure. Otherwise use a small-ish turbo and get it to crank out significantly more torque than the N/A engine. Much the same as Nissan did with the DET. Might actually be cheaper and just as effective to buy/install a DET engine in that case.
cheers
https://www.sau.com.au/forums/topic/130071-turbo-rate-it/#findComment-2406608
People are safely running 14 psi through the DE bottom ends on turbos of similar size down in Melbourne. Making 260rwkw. I have not seen it, however, but this is what I was told. Running more than this would be detrimental to your engine's health. That is also assuming the bottom end is not already "TIRED".
I don't think you will reach that hp figure but good luck with it anyway.
https://www.sau.com.au/forums/topic/130071-turbo-rate-it/#findComment-2406640
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
    • The filter only filters down to a specific size. Add to that, the filter is AFTER the pump. So it means everything starts breaking your pump even if its being filtered out.
