hey guys ive finnaly got the cash to do some mods to my car, i cnt be bothred doin a search, ive got 8000k to spend on my 32gtst and i was thinkin would it be woth spending it on the rb20 or just getting a rb25 put in. cheers guys the rb20 is getting pretty boring. thanks again
https://www.sau.com.au/forums/topic/130078-rb25-or-spend-on-rb20/
im about to undergo the rb25de to det conversion
heres a list of what i got:
front cut inc. gearbox, tailshaft, rear diff end, brakes, and 5 stud conversion.
should cost all up $5-6k inc. install, depending on how much i can afford to bolt on (fmic, injectors, etc)
wats the difference with the NEO Motor. where do u get front cuts from and do they come with gearbox. if i was to purchase the font cut would there be anything else i would need to get ie. Diff tailshaft ect.
Have you looked at this thread yet - http://www.skylinesaustralia.com/forums/in...howtopic=129655
An RB25 is going to have more torque, but a 10k redline would make me giggle like a school girl :O
Also putting an RB25 box in a R32 needs a custom/cut down tail shaft. That may add a fair bit to the final figure. but if your running a 250rwkw RB20 you'll probably need one anyway.
Im using the rb20 gearbox runinng 230rwkw. only drivin it for one weekend but it feels fine so far. IMO its not worth putting the 25 box in coz they still break an the rb20 box is as cheap as chips to replace. Just use the best gear oil you can find.
That is rubbish... the RB20 gearbox is nothing like the RB25 gearbox. RB25 gearboxes are basically the same as the GTR minus the AWD bits.
If you go the RB25DET get the RB25 gearbox too, you will be sorry when you just have to take it back to be swapped out after it breaks down the track.
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
