Hi all,
I brought a R33 this weekend and having to drive it home (1000km) it was so loose in the back end like a big bump in the road and it felt like a trampoline, the back end just about lifted of the ground. It seems really really soft and im a little confused why. Maybe im dump but yeah.
This is what i was told was in the car "Gas shockies (Gab suspension)" Can this be pumped up or what????
Im picking the the shockies are gone but looking at them they look nice and new still shinny paint on them
If anyone can help out, that would be great cheers
https://www.sau.com.au/forums/topic/130098-bouny-back-end-why/
gas shocks don't need pumping up, they are supposed to be a sealed unit.
maybe they are simply set too stiff, so when you hit the bump rather than the shocks absorbing it they pushed the car up into the air, and then the back wheels came down hard.
even in totally stock form the back end feels quite lively, so with stiffer shocks i'm sure it would be a problem!
My pulsar and skyline do the same thing.
I noticed with aftermarket suspension, the rear will bump and kick a bit on rough roads.
I was informed that making it a little stiffer in the rear would get rid of this because the rear was under shocked. Dont know how true this is or how well it works. Have only just set the rears stiffer so will have to wait and see.
What happens when you "bounce" the rear end of the car? How far can you push the back down when you lean on it? What happens when you release the load?
If you get it bouncing, it should stop within 2 bounces - otherwise the shocks are shot.
If you have no joy with the responses that you have heard, i have noticed with cars that are "lighter in the back end" than normal cars, to run a slightly lower tyre pressure in the rear wheels, see if this helps, i would recomend about 32 - 34 in th rear and about 36 in the front. see if that helps with the bouncy effect.
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
