Hi Guys,
As this section is taking off, why don't I offer to make some webspace to use with the cefirosaustralia.com and .net domains? If you guys choose somebody to be the admin dude, we can setup a portal and links to these forums etc. Let me know what you think, it'' be pretty straight forward.
Christian
https://www.sau.com.au/forums/topic/130189-cau-site/
  • 3 weeks later...
  • 3 weeks later...
things happen at 1/2 pace here on SAU... lol hang on while we sort out SAU first :)
Atm, its just looking like a front end for this section, so the forums itself will remain unmodified (same mods etc) but with a nicer front page when you go to www.cefirosaustralia.com
Since its only A31's, C32's and Y32's atm (unless you guys wanna include FWD maxima drivers with A32's and A33's) its quite limited on what we can put on the front page.
If you guys can brainstorm on what you'd like to see on a sorta front page (like the one you get when you go to SAU's front page) then we can get started on implementing it, and then getting a couple of you guys to update/maintain it regularly.
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2517196
If it is only going to be a front end then I think this forum should be a bit more organised. I mean its a "lets put everything in the one section" forum atm.
Definetly needs to be an article sub-forum for all those 4 door specific item. And a member ride section, then perhaps the other crap that anyone wants to post.
My 2c :rofl:
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2522963
exactly, what about c34 and 5, are there any in aus? :)
not yet.... they are sevs eligible, just need to find a workshop willing to crash test one and then start complyin em.
I'd go the gloria over the newer laurel tho.
tops idea will set up members rides section now.
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2523050
  • 1 month later...
Yeah Im getting the same. This is just putting in www.cefirosaustralia.com
Result I get is below
VVVVVVVVVVVVVVVVVVVVVVVVVV
Forbidden
You don't have permission to access / on this server.
Apache/1.3.34 Server at www.skylinesaustralia.com Port 80
https://www.sau.com.au/forums/topic/130189-cau-site/#findComment-2620043
    • Thanks for that mate always a good help
    • It's not really a calibration issue, if the voltage is really at 2V. If the voltage is 2V, then that's what the TPS is putting out, and the Haltech is seeing that and 2V is about 40% open (you know, between 0.45v being closed and something close to 4.5V being fully open). So, that would suggest that the TPS is maladjusted, on crooked, something something something. Or a wire problem.
    • Hi guys my TPS voltage is reading over 2v at idle.  My Haltech ECU is reading around 40% throttle position at idle also which is really strange. Note the actual throttle position sensor is brand new…    anyone have any experience with this or know how to calibrate it on Haltech ?
    • The OEM disk will not work on any AEM ECU, you need to use the one they made. You shouldn't have to flip the CAS or whatever you were describing, if you set the ignition sync offset correctly it can't backfire. Make sure you're using a spark plug lead on coil 1 instead of the timing loop to avoid weird issues with the timing light. Double check that your timing settings are actually correct, like is the 24 tooth configured correct or should it actually be 12 teeth for 1 crank revolution? I also found this: 305817248-AEM-Undocumented-Settings-v1-2.pdf
