Wtb: 17" Gtr Offset Rims For Track/drift Use.
Hi all, i'm looking fer a spare set of 17" rims fer track and drift use. Preferrably at least 17x8. The cheaper the better but price im willing to pay depends on rims itself. GTR32 offset needed.
PM me if u have any fer sale.
Cheers~
Edited by J-Boy
Thanx Deni...but i really dont need the road radials...would love to just buy the GTR33 wheels but without tyres cuz im only gonna use semislicks with it...
Hi there, I have a couple of possibilities that you or someone else might be interested in. Firstly, set of Enkei lightweight 2 piece wheels 17 x 8 and 17 x 9 and +35 offset I think. 275/40/17 tyres on rear - small amount of tread. 245/45/17 Yokahama 048R semi-slick tyres on front with only a little life left in them. $750 set.
Also a set of lightweight Volk Racing 2 piece wheels of the same basic dimensions. These wheels use the PCD adaptors for bolt pattern and offset. No tyres. The two 17 x 8 rims have a couple of small cracks in inner rims to repair and are fairly well used. $300 set.
Can anyone interested please call me on 0416076187 as I do not always check my computor. I am in Sydney.
dat120y: thanx...but the offset i need would be somewhere around +22 and im looking fer a width of ard 9J on all 4 wheels...good luck with the sale~~~
Cheers~
I've got a set of wheels similar look to the first ones posted by 'dreamaut0works'.
All four (rims only)
17x9 +20 offset all round.
PM if interested.
I've got a set of 17x9 with an offset of +22 would be perfect for your usage. They are the advan three spokes
The tyres i have on them are the falken semi slick style thread, but different compound... think they are 235/40/R17s with about 50% thread on them.
1k the set
Send me a pm if you are interested.
Cheers
Liz
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
    • It's TWO steering wheels actually. 😛 one for each hand They are wheels, and they steer!
