  • Replies 46
Guest neoGT-25
your friend is exactly right... i live on government road in a townhouse complex :P
oh and to answer the "U say in there (from 174kw to 188kw) how did u get to 174kw.. i thought they were 145kw stock..?" question
i dont know... its just what the mag said... i dont drive yet so it would be had to cruise LOL
what school did you go to? i go to benowa and its a crap school :P
and also i wouldent know where to buy parts :P
hehe... byes :burnout:
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-252013
haha madness man, i cant beilve u have a r34 and u are still in school u lucky basterd :P
yer i was at helensvale high man graduated in 99, yer that was a wicked school i had some good times there.
i lied im not really in biggara water i live about 2 mins from u u know whiting street...brown st im just down there :P
small world :P
are u licenced to drive it yet or not??
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-252065
From what martin donnan said about his partners car
R33 door, auto RB25DE,
he recorded a 9% increase in power at the wheels with a 5zigen cat back exhaust.
impressive i think.
cam shafts, i have heard u can install some tomei cams, that dont requre ecu upgrades,and provide a 10% increase as well, get some adjustable cam gears to dial in as well.
An altenative to getting totally new cams is to reground the existing cams, though a side effect could be roughness in the idle, but i think i could live with that. :P
SAFC will make the most of you cars stock air/fuel ratio by maximising it.
i am desperatly saving for all of the above, and through a top bloke i could land my self a 5zigen R33 na cat back, wahoo
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-252261
Just read that HPI article on NA tuning.
The results that they got, are CRAP.
after a cat back, 2 different extractors, 2 HKS camshafts with cam gears. And an apexi SAFC.
its only 88rwkw, up from about 72/74rwkw. Shit in my opinion.
i plan on getting all the mods mentioned, and from the research ive done, i will make alot more then 15rwkw
https://www.sau.com.au/forums/topic/13035-my-car/page/2/#findComment-255238
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
