Hi All,
Unsure who to speak to, I was initially speaking with Chris and Adam in relation to this, but nobody has replied to my emails in over a week, and am getting concerned about my payment made on the day of DECA re: CAMS membership and an SAU membership.
In all, I paid $265 to SAU for an entry for DECA, an SAU membership, and a CAMS licence. $155 of that was directly deposited into the SAU bank account (which I have a receipt for), the other $110 was a cash payment made on the day of DECA. There was some confusion going on about which licence I was to have etc, as I had initially paid for the AASA licence then switched to CAMS as I'll be racing as of next year etc.
My cash payment has gone missing, along with any records of me paying. I'm not a thief, and would never consider robbing a car club of $110. Especially such a minute amount anyway.
Could someone from administration please assist in clearing this up please? I am wanting to come to some of these exclusive meets soon and I can't see anything on the forum!! :D
Thank you! :O
Theo
https://www.sau.com.au/forums/topic/130438-sau-membership/
OK all sorted. I received the membership form without any payment and assumed it hadn't been included. It was an internal error I'm sorry. In any case you're sorted. I'll get the gear out ASAP and you forum membership is done.
I havn't been near e-mail in a week or so as works been hectic, sorry for the delay and issues.
https://www.sau.com.au/forums/topic/130438-sau-membership/#findComment-2414230
On a similar subject, should i be expecting anything from AASA?
Paid at d4d but haven't gotten anything yet...
Seems to have happened to Justin and Sarah as well...but they've been waiting even longer
Dezz, AASA do take a while to send out your license card. I paid for mine @ the DECA last year in November, and i got the card in Feb! You'll forget about it, and thats the day it'll turn up :woot:
It won't happen overnight, but it will happen.... :)
https://www.sau.com.au/forums/topic/130438-sau-membership/#findComment-2414663
Hooray! :)
Nah, no dramas folks, just got worried that my cashola had gone missing and I would have had some explaining to do etc. Thanks very much for chasing up, much appreciated :P
Looking forward to attending some meets very soon!
Cheers,
Theo
https://www.sau.com.au/forums/topic/130438-sau-membership/#findComment-2415683
For anyone who paid for a CAMS or AASA licence at Drift for Dummy's, I can confirm that they have both entities recieved the money + forms, and licences have been printed and should be posted already if not today.
Ta, Chris.
https://www.sau.com.au/forums/topic/130438-sau-membership/#findComment-2419778
Guest
    • Did this end up working? Did you take some pictures?
    • And finally, the front lower mount. It was doubly weird. Firstly, the lower mount is held in with a bracket that has 3 bolts (it also acts as the steering lock stop), and then a nut on the shock lower mount itself. So, remove the 3x 14mm head bolts , then the 17mm nut that holds the shock in. From there, you can't actually remove the shock from the lower mount bolt (took me a while to work that out....) Sadly I don't have a pic of the other side, but the swaybar mounts to the same bolt that holds the shock in. You need to push that swaybar mount/bolt back so the shock can be pulled out past the lower control arm.  In this pic you can see the bolt partly pushed back, but it had to go further than that to release the shock. Once the shock is out, putting the new one in is "reverse of disassembly". Put the top of the shock through at least one hole and put a nut on loosely to hold it in place. Put the lower end in place and push the swaybar mount / shock bolt back in place, then loosely attach the other 2 top nuts. Bolt the bracket back in place with the 14mm head bolts and finally put the nut onto the lower bolt. Done....you have new suspension on your v37!
    • And now to the front.  No pics of the 3 nuts holding the front struts on, they are easy to spot. Undo 2 and leave the closest one on loosely. Underneath we have to deal with the wiring again, but this time its worse because the plug is behind the guard liner. You'll have to decide how much of the guard liner to remove, I undid the lower liner's top, inside and lower clips, but didn't pull it full off the guard. Same issue undoing the plug as at the rear, you need to firmly push the release clip from below while equally firmly gripping the plug body and pulling it out of  the socket. I used my fancy electrical disconnect pliers to get in there There is also one clip for the wiring, unlike at the rear I could not get behind it so just had to lever it up and out.....not in great condition to re-use in future.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done. In my case the BC Racing shocks came assembled for the fronts, but the rears needed to re-use the factory strut tops. For that you need spring compressors to take the pressure off the top nut (they are compressed enough when the spring can move between the top and bottom spring seats. Then a 17mm ring spanner to undo the nut while using an 8mm open spanner to stop the shaft turning (or, if you are really lucky you might get it off with a rattle gun).
    • You will now be able to lift the parcel shelf trim enough to get to the shock cover bolts; if you need to full remove the parcel shelf trim for some reason you also remove the escutcheons around the rear seat release and you will have to unplug the high stop light wiring from the boot. Next up is removal of the bracket; 6 nuts and a bolt Good news, you've finally got to the strut top! Remove the dust cover and the 3 shock mount nuts (perhaps leave 1 on lightly for now....) Same on the other side, but easier now you've done it all before
