grinder if u wanna go really dumped...
check out SydneyKid on the Group Buys section of the For Sale part. he has excellent R33 suspension upgrades.
i thought that if you take a grinder to springs they can bend out of shape or sumthin?
https://www.sau.com.au/forums/topic/130462-lowering-a-33/#findComment-2415909
backyard + grinder.
haha yeah if you want cheap...then as Mitchy said.
By far the cheapest, but not necessarily the best :huh: by cutting the spring you are reducing the bump height, and the standard spring rate might not be enough to cope with roads. If you want to just go springs, buy a set of heavy duty super lows that have the spring rate to cope with the reduced travel :P
I am sure it's also illegal to have cut springs :)
https://www.sau.com.au/forums/topic/130462-lowering-a-33/#findComment-2416008
when doin springs change shocks as it f*kts the ride of the car makes it soft
or go coilovers like teins or jic
i got D2s on atm and they are shit as some can maybe tell u
I have D2's on mine now too after my JIC's shat themselves. Definitely not as stiff a ride now...not sure whether to rebuild my JIC's and try and sell the D2's, or sell my JIC's as they are and let someone else rebuild them and use them :(
https://www.sau.com.au/forums/topic/130462-lowering-a-33/#findComment-2419261
If you want a lower custom ride hight, come down to REPCO where i work. We can get you in custom springs from King Spring, Our price will be the best price around for new springs, Lot better then any sespension shop. For more info PM me.
Jaker, Does repco fit? Does repco align? Can repco tell me the spring rates? Can repco give me any details at all of the EXACT result of the "Custom King Springs"? Can Repco design me a set of springs to my EXACT requirements? To say your better than "any sespension shop" is a very big call, especially when you struggle to even spell Suspension correctly. My suggestion if you definately want King Springs, off the shelf or custom, would be to contact Wilkinson Suspension as they have been the distributor for kings for a lot longer than repco. (and happen to be a SAU Sponsor)
Just my 2c
Regards
Brad
https://www.sau.com.au/forums/topic/130462-lowering-a-33/#findComment-2421367
Im not saying that were better, im saying our prices are half the price.
All you have to do is go into a shop like Wilkinsons and tell them what you want and they will tell you what rate and height you need.
Repco can fit, spring rates, yes we can cause you tell us if you want customs, EXACT, of course you knob because you tell us what you want. WTF do you think CUSTOM means, as i said there are off the shelf and then their are custom springs.
At the end of the day how hard is if to install springs, if you cant do it go to wilkinsons to get them to install them. All im trying to say is we can get them cheap, sorry to stand on a few toes for helping out. Most staff at repco might not know how to help you out, but me and my mate know skylines, so no harm in getting a quote.
https://www.sau.com.au/forums/topic/130462-lowering-a-33/#findComment-2431651
ive just got standard shocks with king springs 50mm lowered or somethin. they were in the car car when i bought it. i havent had any issues and prev owner babied it and he never had an issue.
i do agree if your gonna do springs wait and do whole lot but if ya aint got the cash do what ya can or wait :(
https://www.sau.com.au/forums/topic/130462-lowering-a-33/#findComment-2431893
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
