hahah yeah but thats coz they're fishing for another.
my bitch is just shy because she knows she needs surgery! :P
the body is pretty straight though...a pin hole dent and a small dent on the right front guard (all there from japan)...its just the rear bar, front bar, sideskirts that need the respray, and the body could do with a touch up here and there....
overall though i'm happy with how it came :)
haha my girl needs the surgery.. Its got a weak bladder and is leaking from the rocker covers, P/S is leaking, Bonnet is white, and back window is all sh!t...
damn
thats 1 thing about my car im happy with. engine wise its been pretty much trouble free since day one
Found an awesome location and took some photos of mine and a mates (hes on here as mbs206) r33 on my camera phone - 3.2megapixel k800i 8) :lol:
Car is dirty, cbf washed it as it will just rain again - plus the brake dust looks the goods imo :lol:
I like the last photo.
http://server2.uploadit.org/files/frozenchook-mattwater3.jpg
Great location. Would've been perfect with a proper camera and a circular polariser to get rid of the reflection in the windscreen, and a bit of HDR to get the detail in the sky.
Thanks
I do plan on going back with a proper camera - and some gumboots lol
what does look aswome is
is that your ride
Note click thumnail for large photo
EDIT what would that be worth as a poster wil
Thanks dude, yep that's my car :).
It's $25 for a bit bigger than A3 -> (297mm x 440mm) on proper thick photo paper. (professional print, NOT inkjet or local photo store print)
$40 as above but also hot laminated with a black border.
I have it up on my wall but it's 420mm x 622mm (which is slightly bigger than A2). Cost is a bit more too for that.
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
