looks like the factory paint, 'super clear red' to me Al :D
Doubt it :D
Car looks like a '95 model (S1.5), Red only came out in S2. Also the colour "pops" to much in the sun, very pearly. My pics make my paint look alittle darker on my car; i would love to put the two cars side-by-side.
Al, FYI:
AN0- Super Clear Red
AR1- Super Clear Red II
I'm pretty sure the first one is your factory color...what i'd call burgundy, but Nissan Japan see it as super clear red....Super clear red 2 is a much rarer factory color
Doubt it :D
Here's some pics...1 is obviously a series 2, the other is a 1.5
Those 2 were actually owned by the same guy...I did some research on the color when I was in the process of buying my car, because I almost bought 1 in the color, and didn't think it was a factory color at the time, having never seen it before...Until I spoke to this guy (member on here) and he told me its a pretty rare factory color :D
I've got more photos of it on other cars as well...surprising how much it changes in each of the photos too...looks really dark in some, but put it out in the sun and its quite a bit different, and a much nicer red when in the light
Shes a fresh import, and the paint job was done around a month ago or so. Originally it was a maroon/burgandy colour and dont we all hate that stinkin colour :D (no offense to burgandy sky's out there).
The colour is more like a Ferrari red, very different from factory red colour that came out in series 2. When the sunlight hits the car, she lights/brightens up like a flower, looks much better in flesh these pictures dont do any justice. I cant remember the paint code now, but will get it some time soon.
If i see anyone copying my colour, i will come knocking on your door step :D
R-SPEC
yeah that was me, you were in the purple r33? :)
:P
You copied my paint job :)
What is the name for that paint and the colour code?
post-1811-1165492549.jpg post-1811-1165492834.jpg post-1811-1165492962.jpg post-1811-1165493104.jpg post-1811-1165493149.jpg
Nice car by the way :(.
Looks like you have a decent camera :)
Ive said it before and ill say it again, thats got to be one of the best series 1's ive ever seen!!;)
Edited by nizmo_freek
Shes a fresh import, and the paint job was done around a month ago or so. Originally it was a maroon/burgandy colour and dont we all hate that stinkin colour :P (no offense to burgandy sky's out there).
If i see anyone copying my colour, i will come knocking on your door step :w00t:
R-SPEC
yeah that was me, you were in the purple r33? :O
i was in a black n/a r33. you overtook me then pulled up next to ya at the lights. was gonna highbeam you to let you know about the camera they've set up at those set of lights coz you seemed to be doing a bit more than 60ks but didn't ;)
your car looks and sounds nice!
Ive said it before and ill say it again, thats got to be one of the best series 1's ive ever seen!!:)
Thanks buddy, appreciate it :(
You car looks very clean. I personaly love silver, as it is the easiest colour to keep looking clean. Some nice rims (dark spokes and polished dish) would really set the car and colour off. :)
It has now been just over 2yrs since my car was painted, and am still very happy with the colour choice and workmanship. Due to normal driving and SAU motokahnas it has a few chips, but that's to be expected.
if u wanna see my sky check out http://www.bebo.com/Profile.jsp?MyProfile=Y oh and ignore the stupid burnout in my vid... it was just for fun i lost my licence and i needed to just screw around for fun in my car since i missed driving it... and if u dont wanna check out my page u can see a pic of my car in my display pic :happy:
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
