it's ok alex! got your specs off another thread!!!
i'm running 18x10+18 on the rear just trying to figure out what to get on the front!
was thinking of trying 18x9.5+18ish but my car isnt really that low!
yeh im running 18x9.5 +15 front 235/35s but i have +20mm front guards so on stock guards even with a roll sticks out by a fkn mile id suggest maybe +30ish to keep it more in the body unless you like mexican which i doubt :( but be careful i got some work eurolines 18x9 +30 only fit with 25mm spacers cos deep dish design and brake calipers thats why i went with mismatched and it kinda suits my car style.
haha i quite like mexican!
even now starting to think 18x10+18 is not wide enough if i go lower! probably want to flare my rear guards and go to negative offset territory haha
atm the fronts are rocking 17x9+22 my skid rims so illl work from that!
dont go mexican hellaflush is where its at not to mention police and mexican fitment dont go well together. depending how low you go 18x10 +18 is gonna give you headaches even with a flare which i dont think suits the r33s as much as say an r32.. just roll and camber the fkrs in be tough as!
post pics when your done. :)
i like the little wave there damage nice :)
cheers man
got anymore dude? loven the orange with black bonnettttt
yeah got a couple , let me see what i can dig up
couple of big ones :
http://img407.imageshack.us/img407/8527/img0888f.jpg
http://img444.imageshack.us/img444/5940/img0846d.jpg
well heres how it sits atm with 17x9 +22 18x10+18
its sitting pretty flush car definitely needs some low!
also probably getting some 18x9.5 +28 meisters for the front might run a spacer depending on how it looks but should sit the same as it is now
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
