Hi all!!
Tuesday night dinner is at the Norman Hotel - "Brisbane's worst vegetarian restaurant". Yes, this means they have steak. Lots of it. Huge, thick steaks. :)
I've posted up early to give you time to put a few extra dollars aside - it's not going to break the bank, but these are very high quality steaks. Meals vary between around $10 up to $33 for a huge rump steak. It depends on what you order, but believe me they are worth it. They do have meals with chicken or fish instead of steak, but if you're not a carnivore you're out of luck.
When: Tuesday, 22 August at 7:00 pm
Where: Norman Hotel, 102 Ipswich Rd Woolloongabba 4102, (07) 3391 5022
RSVP: 12pm on Tuesday, 22 August. We will not book extra seats just in case someone arrives, if you turn up and haven't RSVP'd, you sit at another table.
Map: Clicky
Menu: http://www.normanhotel.com.au/ then click on "Dining"
Come along, enjoy the company (maybe :P) and meet your fellow SAUers!!
Cheers
Marc
https://www.sau.com.au/forums/topic/130521-tuesday-night-dinner-22-august/
  • Replies 59
Posted Images
i am pretty much in!!...
Big Norman sounds good... though i have to leave room for much alcohol afterwards, as i believe i am going out (possibly)
Does steak absorb alcohol??????
Good time to experiment..... :)
C'mon Col...where are you?
You should be coming along....mmmmm steaks :P
*you know you want me*
Training next tuesday night for me...
Some noobs need their shoes tied on the topic of "Corperate Leasing" Pfttt easy...
I love steak too, its my favorite...
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
