Hey guys n girls! does anyone have a 1996 Series II GTST and take it to a professional to service?? i was just wondering wat sort of price u guys pay?
PLz can everyone not say Service it yaself!!!! cause i know its cheaper!! i just wanna know if anyone actually takes it to a mechanic to service and wat sort of price they pay.....
https://www.sau.com.au/forums/topic/13055-does-anyone-service/
Sure do, take my car to Mark @ Hills Motorsports (02) 8802 0777.
Here's a few things to give you an idea of pricing, obviously each individual service would be different however this should give you an idea of cost.
Labour at Hills is about $80 p/hour ... All of this will most likely be around 7.8 Hours of work, so around $624 in labour.
All these prices are off my latest invoice, they are ex GST ...
Fuel Filter - $16.36
Oil Filter - $16.36
NGK Spark Plugs - $3.5617 each (six required)
P/S Belt - $30.51
A/C Belt - $ 28.09
Alt Belt - $14.50
Timing Belt - $89.82
Thermostat - $42.57
Water Pump - $139.18
Castor Rod (pair) - $86.36
Brake Fluid - $18.18 p/litre (2.2l required) Motul Fluids Used
Clutch Fluid - $6.32 p/litre (1.1l required) Motul Fluids Used
P/S Fluid - $30.908 p/litre (2l required)
Engine Oil - $14.57 p/litre (5l required) Royal Puple Fluids Used
Gearbox Oil - $25.69 p/litre (6l required) Royal Puple Fluids Used
Coolant + Flush - $30.908 p/litre (2.5l required)
Hope this gives you an idea of what you're up for :D
Things that anyone can do themselves requiring no paid labour
Engine Oil
Oil Filter
Fuel Filter
Will cost you anything up to $100 in parts depending on brand and afew hours of fun.
I changed these things for the first time ever on my Skyline without a problem at all.
yea true, doing it yaself is cheaper... But some of the things jimbo listed r pretty tricky and better off to have a pro do it... i know for sure i can change oil, oil filter, and fuel filter.... but other things i dont wanna do, so i guess i gotta take it in to get a service from a pro....
im fifty/fifty now!! i dunno wether i should do it myself or take it to a pro!!!
Very true i agree with that, but why let your mechanic charge you $60-$80 for an hour just to change your oils when you can do that part yourself and then just drop ur car off for the remaining things.
My car hasn't been -properly- serviced in ATLEAST 15,000km, just the oils have been replaced. It doesn't miss a beat and puts out a considerably nice amount of power.
anyone hear of the saying "a little information is often dangerous"...well i think this rings true to *most* DYI'ers...
sure i can change oil, but thats about it. i havent got the tools nor expertise to do most other things. besides this, they could probably spot vulnerable points alot better than you could (and of course charge you excessively for it) which is another advantage of letting someone who knows what there doing do it.
if you care for your car, let a professional do it.
franks i agree mate!! i can change my oil no probs, but i dont have the time and tools to spot or fix anyother probs!
when it comes down to it guys, u basically need a mechanic u can trust and know he wont bullshit ya...
luckily i have found one in the nrth beachs and he has a skyline of his own and dies for skylines! so i trust him fully!!
Originally posted by Sumo
I replaced my clutch and im not a professional? nor do I have a trade in car mechanics...
Sumo
even professionals f**k up. my friend had his clutch replaced by a certain well known performance shop in sydney, they negelcted to change some seals and the clutch was stuffed again a week later...
sumo my point is, anyone can turn a spanner, undo a few bolts and figure out how to put something back in and tighten it all back up. infact anyone with half a brain and the service manual could do it....it is however in certain cases, just like the above, that we should be aware of our own *limited* capabilities...
just one more point, im a software developer but i can build a PC from scratch, but when i first switch the thing on after rebuilding, i always have my heart in my throat in fear that it doesn't work ...
I used to have a fear of putting in the bios power cables the wrong way and causing a cloud of smoke.
Now i support customers just by telling them to restart their PC :P
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
