this is a r33 series 2 i bought damaged and have been slowly fixing it up :)
this is it when it first arrived from the tow truck
pic of it getting pulled apart
engine been removed
i then purchased another skyline series 2 for the parts which the whole car was f**ked accept the front end
i then got my car ready for trial fit of the front end ( doing cut and shut to firewall )
now i have it all clamped into postion and trial fit everything
front end is currently getting sandblasted, followed by priming it, then welding on :)
thought some people might be interested anyway enjoy !
  • Replies 40
How will you be rewelding it?
Are you taking it from the seem at around where the seats are?
did you unstitch it at the seem and slide it into the chassis rail?
The reason why I said it looked like a death trap is, I hope you're not just literally chopping off the damged bit and welding on the new front?
those cuts on the rail are with the oxy as if im going to join to that
ive unpicked the rails to factory joins by drilling the spot welds abit under the firewall
i will be plug welding them back up with the mig as i cannot re spot them in that postion
no im not cutting near the seats which most people do
i am qualified panel beater btw.. :(
Well from what i've been told by VicRoads, they're illegal...
If they are in fact illegal, panel shops doing them all the time doesn't make them legal
that is a stupid thing to say.. i dont recall saying anything about panel shops making them legal
and as i previously said i dont know the vic laws nor do i really care.
To my understanding of metal properties, once you stress metal ( ie smashing the front end ) you loose alot of the metals strength then cutting and welding the chassis with a vertical join I dont see how it will be stronger.
Being a qualified panel beater just means you can do the job on the sly , My dad and brother are both qualified panel beaters and they both said its illegal straight away .
You would have been better getting another car where the chassis is okay (maybe a roll over ) then build from there.
im not here to question you or flame you mate. Hope your car turns out well. Wish i could be bothered taking two wrecks and making one car hehe. is it working out cheaper for you than buying 1 good one ?
keep the progress updated :D
Much respect for the sheer amount of work! Not my cup of tea though. I seriously hope that you will inform the potential buyer should you wish to sell in the future.
In relation to the chassis will there be any compromise in the chassis structual rigidity?
Edited by Remix-
Coming along well!
The thing i cant understand is if this is so "dangerous" as others have put it, how the hell do hot rods, utes, limos etc which have had an altered chassis mods still get rego and drive on the street??
I assume everything in this case will be strengthened and done properly
I think when people hear cut and shut they think backyard job automatically? Bit of a stereotype methinks
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
    • Did you hit up the search function? R33 and greddy and cable returns this thread with some options.   https://www.sau.com.au/forums/topic/358214-rb25-throttle-body/
    • Thanks buddy.. the standard one needs to be about another inch or inch and a half longer. Thanks anyway
