Hey all, I am buying a SII R33 GTS-T 5-spd manual in November this year and I have a question for you. I have driven a mates R30 that had an RB20DET (i think thats the write code/term) in it with a massive front mount intercooler and a pod filter. This thing sounds F*%KIN NUTZ!
At low revs you can't hear anything, if your in neutral and you rev it you dont hear anything out of the ordinary, just a engine reving, but when you begin to move as the revs get higher it sounds like a jet taking off. sounds dumb i know but its the best way for me to explain it. It's like air is being sucked into it. when you release the accelerator it makes a whoosh kinda like a blow off valve but better. BOV's have always sounded a little tacky to me. This car dosnt have an aftermarket bov/wastegate on it. My friend recons its the pod filter that gives it the induction/air suckin sound. But im a lil hesitant towards that because i know plenty of n/a tuned cars with pod filters on them and they don't sound like this.
Can anyone suggest what i do to my stock R33 to get it to sound like this? cheers.
https://www.sau.com.au/forums/topic/131065-sweet-suction-sound/
A pod filter will give you the induction noise.
Big difference between N/A with a Pod and Forced Induction with a Pod.
If you go the pod, try to get a heatshield made up. You will still have the induction noise but its not a defect and it also helps keep the air cooler by not sucking in the hot air from the engine.
thanks for the reply mate,
1. does placement of the pod matter? his was right near the road
2. any links on making up a heatshield?
3. will i get a release/whoosh sound when i take my foot off the accelerator?
Even if the filter is in the standard position it will still make that sound.
Have a search on here to find more info about the heatshields. :D
EDIT: And yes you will get a sound when releasing.
Edited by Stel
im getting mine installed tommorrow - i will post pics when its done
thanks man that would be awesome.
so if i install a front mount intercooler it wont make any sounds? just add performance right?
p.s. im so confused. read this. http://www.skylinesaustralia.com/forums/in...=126568&hl=
is it just me or does everyone have something different to say?
Edited by Rochey
Not sure why you're so concerned about the induction noise, most people install a pod for the performance gain :D
In any case, the answer is yes, a pod will give you the sucking sound and a kindof woosh sound when lifting off the accelerator. If you want even more induction noise, fit a larger turbo as well :D
Not sure why you're so concerned about the induction noise, most people install a pod for the performance gain :)
In any case, the answer is yes, a pod will give you the sucking sound and a kindof woosh sound when lifting off the accelerator. If you want even more induction noise, fit a larger turbo as well :P
i just love the unique sound the car has. i hate seeing r33's with massive exhausts that sound like try hard v8's. i'd rather keep the exhaust stock, or change it for performance only and ensure it isnt too loud. i'd rather people say 'hey that skyline sounded mad!' not 'is that a hsv? ah no its a skyline trying to sound like it has a v8'.
if you catch my drift. anyways can you or anyone recomend a good pod filter?
Got my pod installed - sounds good - the power gain is not as much as the exhaust though. Will post pics tommorrow :)
As for blu3chips question - with batmbls front dump and cat - mine has this sorta high pitched sound - almost like u can hear the air flow sorta. Sounds cool in my opinion. But the main thing i noticed is the responsiveness - the car is soo much better off - and a bit better on the fuel too for some reason :)
yep a good hks pod filter will make a sweet sucking sound/fighter jet sound on a standard gtst when it comes on boost - when your on boost and you ease off the gas it makes a lush pphhhtttssshhhhh sound which you can control depending on how quick you take your foot off the gas. My friends gtst is running at 1.4bar of boost on a hybrid and his sounds even beefier - mine is more like a high pitched hissing... his is like a really bassed up hiss as its just pulling so much more air in.
pod filters dont give a massive performance gain but they certainly sound mint :)
hey Rolls:
so blocking off the standard Bov will create turbo chatter is that right? Is there a link on here to a more in depth talk about it?
ta
ant
newcastle
uk
Induction noise is annoying - wayyy too boy-ricer for my liking.
Got a K&N pod filter in Maxx's CAI box with clear lid. Ive filled up the box with heat resistant foam to try to deaden some of the induction sound. Quieter and liveable at this stage, but when on boost damn it's still loud.
Meh
' date='20 Aug 2006, 09:16 PM' post='2423971']
bigger turbo...
You would tinks so...but it really depends, I was running the stock turbo with an Apexi filter..the induction noise was loud as, I changed to a larger turbo with stainless induction piping still using the same filter and the noise is now close to a stock airboxed skyline (Maybe 10% louder) So I imagine it depends on the design of the turbo! A few of my mates have experienced this also so it leads me to beleive if you want loud induction the stock turbo is best!
Meh
I agree...the induction noise of my car before the upgrades was insanely loud and actually a little embaressing as with the stock turbo even giving it a little bit of throttle around town to make a lane change or what ever would cause it to make that stupid sound ><
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
