  • Replies 46
mac33r, go down the pacific highway towards north sydney. turn right @ the miller st lights. turn left @ the 2nd set of lights. turn right @ the next roundabout. turn left @ the next roundabout and its just on ur left as u go under the harbour bridge
Another great dinner guys, thanks to all who showed up. Those highway patrol cops deserved some recognition - top blokes, especially knowledgable on their GTR's and of course their ownage of Tosh (Twice) was priceless.
I started to PM everyone the link, but now I can't be bothered. :)
Anyways, if anyone didn't realise, there are a couple of galleries on my webspace:
http://members.optushome.com.au/dal2
Nick, let Johno know there's some pics of his car there (if you haven't already).
Cheers,
Tex
Cheers. We'll have to scope some more areas to take photos, maybe get some sunset beachside ones (as I was talking to Tosh about earlier today).
Maybe an industrial area at twilight? Somewhere with stairs so shots can be taken from above would be hella sweet...
Anyway, if you've got any ideas let me know. :)
Tex
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
