Guest pawel
I am selling my 1993 R33 GTST
The car is has a new motor 3 litre conversion with forged wesico pistons
new 650cc injectors bosch fuel pump large front mount Intercooler Haltech E6k
computer, Large Garret Ball bearing turbo. runs on 25psi on normal premium fuel no problems. 18 inch wheels. Power figures so far 300+ RWKW cannot get enough traction on most dyno's. Lets just say it beat a Yamaha R1 in a rollon race. Have spent over $20000 in the last 6months. This car is totaly streetable and drivable like a stock car.
Selling $33,000
Sydney
Pawel
https://www.sau.com.au/forums/topic/1311-r33-gtst-500-hp/
  • Replies 85
Guest pawel
Other mods internal mods are it has been ported new rings 6.8.1 compression Garret Turbo 60.1 compressor internal wastegate. Custom catch can. Motor has done 10,000km The car has originally has done 72,000km.
I dont drive it much anymore because I am scared to leave it at shops or anywhere for to long. It also has a full Nismo 400r kit front bar side skirts back bar and still waiting on a GTR rear wing. Any inspection welcome with my mechanic present. Any really technical questions you can also ring Micks Motorsports on 0404 850 942. no pics of engine bay yet sorry. It has red rocker covers powder coated and braided lines for the catch can. Also the car is a five speed manual if I haven't mentioned it before.
https://www.sau.com.au/forums/topic/1311-r33-gtst-500-hp/#findComment-26611
pawel, pity i already have my R33 otherwise i would buy yours.
its a shame you are selling it - i remember sitting in the boot at the dyno day!!
Pawel, if you dont mind... i have these pics...
let me know if you want them removed.
also, i have a shot of the rear, but the plates are showing .. if you want it posted - pm me.
Christian.
https://www.sau.com.au/forums/topic/1311-r33-gtst-500-hp/#findComment-26636
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
