Mine is neither. Its a piece of steel which causes me more angst then any lump of metal should.
Someone have the number of Sims Metal Recylcers?
but urs is a fire breathing dragon.... or maybe its just Drew Barrymore the Firestarter
  • Replies 59
My R32s name is Kitten and its a girl because...
like a girl shes an attention seeker, turns heads. Goes hard and fast. could ride her all day if I had the chance, drains my wallet, theres always something wrong with her, can go from looking hot to getting dirty within 5 mins, and tends to drone alot.
I'm a bit concerned about the responses because my cars a girl, and I'm a girl!!! Eeek.
Lil Blu is a girl because she is pretty, she is always pretty and even when she is not feeling well she is still looks nice!!
Way to pretty to be a boy car.
i woulda just sed its got no balls. period :happy:
My R33 GTR V-Spec is called “Victory” due to the fact that she is a Victory Spec GTR.
Victory has to be a girl because whenever I have the shits with something if I take her for a quick run then I feel heaps better, she costs me a fortune and my wife is jealous of her as I spend so much time with her to the point that Victory is referred to as the other woman.
Have you considered that if you take the y out of victory you end up with Victor.
Maybe you should asses your cars name again. :(:(:):)
Yeah, mine is a dude. Because it has 2 steal like balls hanging off another long piece of steal... I call him Yoshi. I have a few reasons for that name. But the main one is because Yoshi from Mario Brs. eats everything and anthing. And so does my car...
Mine's the biggest bitch in the World making it a chick.
No way a male car could have as many dummy spits as mine so regularly but yet still be loved so much!!
I think she's a bit of a of an sprinter on steriods though. No chick I know could go as fast for such a short period of time. Being an R33, she's also a bit fat for her own good.
Loves having it given to her and enjoys a great spanking once in a while. Such a strip whore and dyno queen :D
She was also nicknames Stella many moons ago. Not by me though. I call her Ribena.
Maybe you should asses your cars name again. :/:/:mad::)
Victory will do me just fine, however my daughter shortens it to Vicky which is a real girls name just to stir me.
Mines a girl cos she's smooth and sexy. Her names Allegra cos in spanish, allegrar means exhilarate, and she sure does exhilarate.
the only problem is i'm a girl too so i guess that makes me a lesbian.
Now i'm not really sure how to tell my parents. :P
Now i'm not really sure how to tell my parents. :D
Don't tell them, bring a girl friend around and give her a good kissing so that youcan show them. :yes::O:O:rofl::rofl:
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
