  • Replies 83
67k I think
I'd say got the F6, seems like the most practical option for what you need it for.
I went through a similar thing about 7 months ago, not with the same budget though. I tested liberty B4's, Audi S3's, C36 AMG's, Audi A6's, and eventually went with a VXII Clubsport. I loved the AMG, but it was too old, and really liked the S3 too, but it wasn't really practical for what I wanted the car for unfortunately.
Liberty STI isent available in Aus is it?
Been in a Liberty GT, wasent that impressed
Was at the HAC event with an owner of one who took me for a little drive. Very nice inside. He is a member of the Rex club.
What about a Chaser or Cefiro? Leather, cruise, climate, sun-roof, :wave: and
you can modify. This will impress the clients
I know its probably not big enough, but I would take a Golf R32 over F6 anyday
Buy a Chrysler 300c, they have a great upspec model....not sure what is called though.
Leave the holdens(V Series) for the young kids. :P:):(:(:D:D
The new model is out though.Check out the SS,
Was driving next to one of these last night and thought to myself, thats one car I wouldnt mind. Might be a bit small for driving people round and is only 3 doors though.
The new model is a V series too... :O
Id go this
AIMGAIN Chaser rolling on 20 inch Carlssons. Probably hide a T04Z 1.5 JZ combo under the hood. Give the E55/M5 crew hell.
Leather the works droooll.
Probably could do something like that much less than the cost of a FPV and have a better looking, faster and more unique car. My uncle had the FPV falcon as hes last company car and he said it was one of the worst moves he made it cos it was such a bucket of shit, always with mechanical failures and just poor overall build quality. I know many FPV owners who said buying the car was a big mistake.
To do something like that on a rough basis.
1999 Chaser Tourer V high km example - 17k
Rebuild + engine mods - 15k
Paint -6k
Kit 3k
Wheels -8k
Interior 4k
ICE 3k
Extras - 4k.
Look on the bosses face when youve destroyed his 400k Merc? Priceless.
Thats a whole lot of car for under 60k. Or you could get a stock Evo/FPV. I know what id choose.
Id go this
Paint -6k
Kit 3k
Wheels -8k
Interior 4k
ICE 3k
Extras - 4k.
My original though exactly.The car spells....L.....U......X......U.....R.....Y and S......T......Y.....L......E.
Shiti can spell :P;):laugh:
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
