Pics Of My New Wheeles And Air Brushing,,,,,,,
By patrickxdf12 · Posted
Hello! i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4 -
