so i have made my own earthing system, and i wanted to add in a voltage stabiliser module...
where can i buy a module on its own (cheap!)?
i tried jaycar but they said the only ones they have only handle about 1 amp and that's not suitable for a car is it?
i don't want to buy a brand kit because that's just a waste of money in my opinion...
can anyone help?
cheers,
Warren
https://www.sau.com.au/forums/topic/131330-diy-votlage-stabiliser-system/
why do u want/need one of the things? any problems (dimming lights etc) or just want to do it?
while on the topic, does anyone know what the internals of those things are? alot of the car audio guys dont both with them i dont think... just use much better earthing
In my opinion voltage stabilisers are unnecessary if your electrical system is in good condition.
Revs rise and fall with electrical usage because of increased load on the alternator not because the voltage drops. A stabiliser won't have much of an effect on this.
If you run a race car without an alternator then you need something like this to maintain a fixed voltage as your battery runs down.
http://www.jacobselectronics.com.au/raceaccuvolt.htm
Very pricy but I wouldn't want to try and make one.
The output voltage of the alternator is controlled by the voltage regulator. They are usually a pretty stable device in any car built since 1980. Are you sure you have a voltage problem? Have you checked the voltage stability of your car? A cheap multimeter will do that (~$20 from SupaCheap), a quite usefull device to have in your tool kit. Or a Consult interface to talk to your ECU (~$50 on the Group Buy forum) an even more usefull device. Both unlike an aftermarket voltage stabiliser which is basically useless. If you truly have a problem, then you will have to replace the voltage regulator and/or the alternator anyway.
:D cheers :D
Edited by Sydneykid
SK..
no i'm not sure its a voltage problem at all..
just something that i thought might help but i'm not fused whether it works at all..
i have nissan datascan + ECU interface cable so can monitor my voltages if i want to on the fly...
i might just stick to the grounding kit that i made (basically i just made about 6 grounds between important grounding points...)
thanks all for your help!
Warren
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
