Hi ppl!
I have seen these advertised around the place but I can't find enough info on them about if they actually work as well as they say they do.
The reason I want one is that with the HKS exhaust setup I have, I get alot of droaning within the cabin at low speeds, say between 50-70kms. I've had exhaust places check the setup and say that there is basically nothing wrong and nothing that can be done for it. The fact that it is auto doesn't help and I think makes it alot louder (bloody autos!)
So the next thing I was thinking was to go with this Apexi ECV, which can be adjusted incabin to be half closed or fully open, so that when driving round normally you can adjust it to be quieter, hopefully reducing the droan levels, and open it up when you want to go flat out.
So if anyone knows of these things and how they work with Skylines or 3" type exhaust systems pretty please let me know! :)
https://www.sau.com.au/forums/topic/131598-apexi-ecv/
Looking at it for the 1st time, it looks like all it does is restrict the exhaust flow and (in theory) make it quieter??? Why restrict the flow??? more flow=more pwr.
Being something from Apexi it's probably got a decent pricetag attached and theres probably quite a bit of effort involved in installing it, plus then the on going manual opening and closing the restrictor.
Why dont you just try spraying the under body with sound deadener, and adding some more effective sound deadining material inplace of the original stuff under the moulded carpet (dynamat)? Probably cheaper, easier and just as effective but you retain the POWER!!!
My last car was really droany in 5th at 80km (the speed and gear i was using most often... jst my luck!)
I sound deadened the wheel well and rear 1/4 pannels... made all the difference i needed without sacrificing any power!
thats my 2cents and then sum!!!
https://www.sau.com.au/forums/topic/131598-apexi-ecv/#findComment-2437046
I was lookin into this sometime back and a friend had it on his evo with a full exhaust. No cat, no resonator, with a cannon muffler. I noticed the results were substatial. Also, due to ur car being so free flow, a some part of ur low end torque is sacrificed too. So for normal day to day driving, this thing does help, i felt a difference in the torque for normal driving ( or it might be my mind playing tricks on me ). There is still some groan and moans :) ... but it probably cut the sound by about 60%. It's like putting the screw on air restrictor on ur car at the exhaust tip, somewhere around that lvl, but not as effective. Price wise, as Godthrilla said, it ain't cheap. The valve itself if my memory dosn't fail me costs about $300aud, and the electronic addon another $300 plus.
My friend DIY-ed one for his rex, and for his, it was bloody substantial. The problem is, he dosn't wanna tell me how it's done as he intends to sell it.. for about a grand aud. It's like comaring a rex with a straight through and one that's stock standard. Fuggin substantial.
Personally, ur best bet is to get a resonator tuned for the rpm range u cruise in. Normally it's about 2k to 3k rpm? After which it's a screamer, but of course it restricts the airflow.
https://www.sau.com.au/forums/topic/131598-apexi-ecv/#findComment-2437304
Thanks GODTHRILA, yeah they are about the $300 mark.
I don't know if you'd really loose that much power though, obviously when it's shut you would, but fully open there would be sufficient flow?
Hmm I may have to look into this sound deadener stuff!
Cheers again!
https://www.sau.com.au/forums/topic/131598-apexi-ecv/#findComment-2437340
Hey KeeFy, yeah there is a resonator in there already, do you think replacing this with one that is tuned would be a good idea?
https://www.sau.com.au/forums/topic/131598-apexi-ecv/#findComment-2437346
There's a resonator? Then by right it shouldn't be all that bad.. i think. On that note, i frankly speakin have no idea what to do for your case, cause from what i know resonators and such help reduce the sound. Attached is a exhaust theory website that might be of some use.
http://www.nsxprime.com/FAQ/Miscellaneous/exhausttheory.htm
Maybe we should compare our exhausts one day, i've got no resonator... and it's irritating the hell out of me on long drives, i still have yet to find the $$ to do something about it. LoL
P/s:HKS does make a silent exhaust with performance.. so maybe that could be a possible contender too?
https://www.sau.com.au/forums/topic/131598-apexi-ecv/#findComment-2437680
Yeah it does have a resonator :D
Although it puts out a nice tone, specially when ya put the foot down, but it's just the normal driving that anoys the crap out of me.
I think I may have to look at getting another system!
Thing is I have a mate (really I do) who has the exact same exhaust, but his car is manual and he doesn't have the same droaning problem!??
So who wants to buy my exhaust?? :yes:
https://www.sau.com.au/forums/topic/131598-apexi-ecv/#findComment-2438809
My exhaust is unusually quiet, most cars are louder than mine. I love it that way, because you can hear the turvo spool up a lot more and it's nice & loud :)
Dave I can understand why you don't want the drone because like me you probably hate it, but with the less flow less power thing, obviously if your doing 50-70 you don't need power?? :)
https://www.sau.com.au/forums/topic/131598-apexi-ecv/#findComment-2440480
Yeah it's 3", someone did tell me it looked like 3.5" though! it has a high flow CAT, but it still had a loud drone before I changed it anyway.
Been reading Keefy's link to that exhaust theory website, not bad info, will look into a few things I think.
Thanks ppl!
https://www.sau.com.au/forums/topic/131598-apexi-ecv/#findComment-2440594
yeh behind drivers seat.. the cable runs from there all way just below the driver front seat for easy access.
hrmm.. there is loss of power definately.. but its nothing unbearable. still fine to drive with it all day and it really helps when u got headache on way home from work or if u see some cops close by :P
ill try take some pics soon show u how its fitted on my hr31
tuyen
https://www.sau.com.au/forums/topic/131598-apexi-ecv/#findComment-2456705
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
