Changed My 33 Climate Control Lights To Blue(pics)
I would consider doing all this if there was a way we show the whole legnth of the needles. Anyone actually get everything perfect? As in equal light spread and no dark spots on the needle?
  • Replies 75
yeah they'd be good..maybe i could snap my needles while installing them..
and if not, watching the RPM needle get stuck at 4-5000rpm will be cool :)
+ i dont really want the white faced dials during the day. this "mod" is way cheaper, and does the job perfectly fine for me
i chagned the globes this week but i replaced them wtih normal wedge type globes rather than LEDs...
i used some that i got from eBay.. paid $35 for 6 glboes including delivery
they are xenon+hallogen filled and blue tinted, similar to what you would upgrade to with a headlight
so the results is much brighter and whiter light :D
but it has a tinge of blue in it too...
and i used the last globe (i bought 6 and it requires 5) to change the backlight for the auto trans gear shifter.. from a green to a blue also..
definately brighter and worth the cash!
Hi Guys!
I got 10 of these LED bulbs. They are brand new never installed. Blue in colour.
I no longer require these. PM me if you are interested. I'm sure we can work something out. :P
Kev
Just wondering if anyone has any any success changing the light colour of the cigarette lighter?
I pulled the bulb out but it seems to be moulded into the plastic which has a unique connector. It looks impossible to put a LED + resistor into the plastics.
Any ideas?
Kev
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
