  • Replies 183
Posted Images
Jackie
I should have all the LW vids uploaded tonight, Don't seem to be too many of the Skid pan of the morning,
but seems our video operator in the arvo in between a lot of shots of the tops of trees actually got quiet a few of the battles done as well.
I'm in the process of cleaning these up and should be uploading them in next few days as well.
Jackie
thank u :P
i'd probably just keep uploading them to youtube then
I'm guessing you can't download the videos offline from youtube?
Hopefully once all the other footage gets cap'd we have someone to host it :O
Hopefully once all the other footage gets cap'd we have someone to host it :dry:
Yeah you can't download from youtube which kind of sucks.
Justin is going to be offering him some space to host I beleive :O
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
