hi... im in the middle of wiring up my car and i screwed up... its a rb25det neo... i went to start the car... fuel pump charged up, starter motor cranked... and cranking and cranking... but no start... ive checked my spark and my injector wiring and its all correct... i then went to the computer and it smelt like the smell you dont like to smell near electrics... i opened it up and i found a diode or resistor to be had it... ive got another computer on the way but i want to know what caused it to let go... the number of the diode/resistor on the computer chip is D620... could anybody tell me what that diode is... or where can i get an electric diagram of the actual computer... if i worked out what pin fed this diode i could work out where i went wrong by using the ecu pinout... i cannot follow it back on the card because the card is multi layered or something like that....
thanks for your help
https://www.sau.com.au/forums/topic/131995-my-computer-shat-itself/
yeh wheezy i didnt *gets in line for somebody to shoot me in the head*
oh well ive found another computer... ill make sure that i put a relay through for sure now... what size relay do i ask for when i get it??? 10 amp???
Providing your loom came with the eccs and ign relays which is should have, then you should have a spare green relay left over near the kick panel.
Use that, if its still there.
Otherwise go the wreckers and grab another one off a r31.
Edited by James_03
thanks for that ill do that...
does anyone know where i could find a electrical diagram for the actual computer or tell me what the diode # D620 connects directly to
    • Have you flushed the initial fluid yet? It should look like a rainbow unicorn shat glitter into it. 2nd or 3rd fluid change is when you party.
    • all brand new unit from Tomei, fluid, bearings, etc. Tomei said they call it a 1.5 lsd because its 100 percent lock up under acceleration and 50 percent under deacceleration.  as I mentioned I used their fluid, install and their break-in procedure, (alot of figure 8's) but even when driving straight, or even slowly backing out of garage for first time, (at 2 mph) then driving to and from figure 8 parking lot, each tire in the rear would sporadically grab, skip, bounce, shutter and skip, shutter back a force I could feel causing clutch to slip then grab, at any speed. shaking entire car. I removed unit, since I put stock back in and all is fine, via process of elimination, its something with the lsd unit itself. I wasn't going to beat up the entire car more or change anything else for no reason as I had a feeling something in the lsd itself was wrong as everything was fine before this alone was installed and I rechecked over everything else after first time backing out I suspected an issue. I'll probably sadly already need new tires now just from trying to drive it 5 miles and performing the figure 8 break in. but if someone has any ideas I'm all ears
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
