At subbies a fair bit... was at last Transmission with Zany... Was awesome!
You dont see many younguns... if you do you kick em while they are down... :D
Saw Zany(opening track was Jump around by house of pain. COOOOLL) and DBD at Melbourne Transmission whilst on holidays down there...First time out in Melbourne but man the scene is so different down there. 2 thousand people all doing the Melbourne shuffle in unison. Bit ghey if you ask me.
hmmm, 12 yr old candy wanks gurning and letting thier glow stix fly, throw em back ^^
many many memories of these lil smack tard wanks falling over em selves in skanky shitholes.... yea kinda got over it a few years ago...
hmmm, repetitive sets... over an over hearing some raelly crap mixing and kiddy scratches.... yea phully sik the all night dance party massive... hahahahaha
some have got talent admitedly, some need to learn how to read music,
push your own tracks and il listen aye, re-hashing 10-15yr old tracks gets old.
find me an event with a $15-$20 cover charge that serves alcohol AND has some decent stuff to listen to, breaks, lots of diff house less the 70's throwbacks and hmmmmm yea maybe even a few drum roles an i'd turn up.
lets see...$80+ just isnt worth more often than not... but thas just me eh
to those who went to Magic City
when Dark by Design was on ....u know how he was standing on the top of the speakers stacked up and he was going crazy....the speakers started to wobble and i full thought he was gonna fall off!!!!
...but he quickly jumped off before he lost his balance
These are NOT raves... just techno/trance parties.
A rave, for starters, is by invitation only and where it's held is usually a secret till the night.
but.... carry on.
Damn straight.
Marsss, do you ever host any latino "raves" ?
but.... carry on.
http://en.wikipedia.org/wiki/Rave
A rave (sometimes referred to as a rave party) is an all-night dance event where DJs and other performers play electronic dance music and rave music.
Dude...read the rest of that link you posted.
As law enforcement agencies increasingly began paying attention to raves, concealing a party's location became important to an event's success. To that end, event organizers sometimes either promoted events solely by word-of-mouth, or would only reveal the date and location of the event to subscribers of an electronic mailing list or via voicemail. Some even went so far as to provide a series of clues or map checkpoints that ultimately led to the location of the rave
Yeah i call these ether dance or trance parties. I love them but know they aren't raves.
Someone asked me if i went to any raves this year and i said no. then my friend said yeah you have, you went to transmission. i just laughed at him and said thats not a rave it's just a dance party.
Some people like calling them that i think so it sounds cooler or something i guess.
Had my last one last weekend..
Thats my lil boy..
Dj Bangers.. hes all grown up now :) *sigh* lol.. pretty darn good set too.. it was going off..
haha yeah..matty sims besides you..so tipy :):P
where was this last time i saw simsy was on ice getting smashed by me ahah
if you see him tell alber said hi
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
