hey ppls.
Forgive us im new to this. How good is this place everyone helpin each other out n stuff.
i just got this 4 door.
my ford GT look alike got stolen so i thought i might buy something that didnt stand out so much.
but ppls still stare at this too! some ppl even ask what it is.
anywho, it still looks like a jap granny car. stock as.
can ppls please put pics up here so i can get some ideas for my new baby?
R32s are easy to wreck huh, some bodykits u see that ppl put on just make them look shit as.
https://www.sau.com.au/forums/topic/132133-r32-4-door-very-very-coooool/
hey ppls.
My baby.
well, u wouldnt want it to look like a gtr, unless it went like a gtr.
if u had some sheet metal skills and a weekend (or 2) u could put the 2 door tail lights on there. that would look sweet.
No need to butcher.
If you don't like the tail lights those eastbear covers look pretty cool.
Awesome! I used to have a xw lookalike too. Bummer it got stolen - hope you had insurance. I reckon with my one it never got stolen because it looked dodgy.. I bet they couldn't even open the door lol :)
I love 32 4 doors. It's a pity too because I found pics once of a really good looking one that I wanted to buy... lost them now and definately didn't buy the car :blink:
White, black bonnet, white.. VIP-ish kit, flare guards (or widebody if affordable), fat dished rims.
...after the engine mods :P
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
