theres always a bit of noise, when moving the steering wheel it is loud, when at full lock it is louder.
This happens when the car is moving or not. I'm pretty sure its the power steering pump, can ya fix em or do i have to get another one ?
In the Information and technology industry the first thing a tek will as is for you to explain what it is and is not doing in more detail. I see no resin why this shouldn’t be the case here.
Please what kind of noise is it making?
Squealing, squeaking, grinding or another sound I have not covered here or maybe a few of the sounds all together?
  • 3 months later...
Yeah it was just low fluid level. Very embarassing post !!!
Good to see it was just fluid, unusual that the HICAS light never came on???
Was going to say if it was the pump try make a distinguishing mark on the pump so u can tell if it is a new pump or just your one recoed, seen it done before charging for a new pump & the old pump has just had a seal kit put through it.
Give u a idea your looking at around $50 for a seal kit & about 1/2 hr to a hour to pull the pump down & rebuild it, so say $150 - $200 all done, with new pump say around $450 - $500...
Some thing to keep in mind... :P
how about this?
the hose coming from the bottom of the power steering fluid reservoir is always wet. i noticed this on alot of r33's. funny thing is the fluid level has never dropped. what's that about?
how about this?
Had the same thing with my old 33, fluid would leak out the bottom hose and fill up the surrounding rubber sleeve. Ended up just getting new clamps and she was all sweet.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
