hi guys... ok bear with me while i run this through..
ive had an overly annoying 'squeek' coming from somewhere in the rear for the past 3-4 months, its comes and goes, but sound at times my car sounds like a rickety old trailer at times.... its embarrasing the amount of looks it get...
i took the car to a large suspension related business (not mentioning the name) 2 weeks ago to finally fix the problem, and they said its to do with the adjustable rear camber arms that are fitted to the car, something about them not being fitted correctly by the previous owner... they fixed the problem, for a week....
i just jumped under the car to have another look myself and it appears all they did was smear the arm in some sort of lubricating grease to stop the squeek.. looks super sh!thouse...
im about to get new tyres, as the insides are very worn.. but i want to get the squeek and the obvious camber problem (see tyre pic) fixed before i get new tyres as i want them to last...
my 2 questions are:
Should (when the car is on the jack) the wheel move around at the carmber arm joint (pictured)? it has a couple of mm lateral movement when i push/pull the wheel, and is this related to the god awful noise?
jsut want to get it sorted, as i said, so i get rid of the noise and dont wear out my new tyres too fast.
i want to take the car somewhere with a good rep in melbourne to fix the prob once and for all, who can u recommend?
cheers
james
https://www.sau.com.au/forums/topic/132213-rear-camber-arms-tyre-wear/
The wear pattern is more reminiscent of a toe-out problem than a camber problem.
The squeak is totally unrelated to the tyre wear. I agree, they did a pretty crappy job on the bush - it really needs to be disassembled and re-greased. It looks like a rose-jointed setup - could have worn a bit to produce the slackness you describe.
GT-R rims are about a +20 offset, IIRC, so the rim is sitting out 20 mm further than a comparable GTSt rim. That will load the bearings abnormally and may also contribute to the tyre wear. And may be putting extra pressure on the camber joint.
There should be virtually nothing to very very small amount of play in that camber adjustment. You might want to check its not the rose joint(spherical bearing), if the previous owner put them on and bought them second hand or has used the car extensively for drifting/circuit racing even with new ones they are probably worn and need replacing and that could be the noise and cause of the excessive tyre wear.
Some reading for you;
What is wrong with aftermarket arms
http://www.skylinesaustralia.com/forums/in...mp;hl=spherical
R32GTST Group Buy
http://www.skylinesaustralia.com/forums/in...showtopic=85591
:( cheers :)
Edited by Sydneykid
SK is right about rear camber arms. I got them because I didn't mind the downsides :)
Silicone grease is your friend - remove their muck (looks like it was done by someone who doesn't know where the lube is meant to go) and spray the rose joint. If it's worn as blind elk said that won't help, then remove them :blink: Otherwise I'd keep them till they stop working..
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
