Hey peeps
My tacho and Apexi rsm are showing slightly different readings which vary up to 800rpm in the top end of the rpm range, im curious what a the standard rpm limiter is on an rb20det?
Ive been told 7500rpm but ive also heard 8200rpm??
My speedo is out due to 17' rims n 235 tyres etc, im just curious on wether the RSM or standard tacho is better to go on for the rpms (ie when i want to shift), funnily enough i hit the limiter and the rsm shows 7500rpm and the tacho shows 8200-8300rpm, so i couldnt figure it out by hitting the limiter either hahaha
Anyone know the standard rpm limiter and why the rsm or tacho is out?
Thanks all
Regards
Jaz
https://www.sau.com.au/forums/topic/132239-rb20-rpm-limiter/
Red LINE on an rb20 is 7500 according to the manual (and tacho), but that doesnt mean thats the LIMITER neccessarily...
My rb20 makes power at 8000rpm (tacho/dyno reading) due to the larger turbo, so reving up there is quiet pointful for me but i would agree useless on a stock turbo which is what im sure you are refering to.
Thanks for the help Gary, based on what your idea's are the rsm is more accurate thus the turbo is a little less laggy (than tacho/dyno reading) and the rev limit is abit lower (7500 instead of 8200).
  • 1 month later...
G'day to Jazza if you see this thread! How's it going mate?
My rev limiter seems to be around 8000rpm? I dont rev the car out that much usually but I occasionally find it if the wheels are spinning. Can the stock internals handle this ok? I would've thought the revlimiter would be closer to 7000rpm?
sam (dr drift) remapped my ECU and the previous (stock) rev limit was 7900.
then he raised it to 8800...:)
but on the dyno he revved it to 8000rpm and is has the same power at 8000 as it does at 5300, with only an rb25 turbo
and with max power at 6500, power doesnt drop off THAT fast
usefull to be able to rev the crap out of it for drift, but thats about it.
Edited by salad
Rb20s need revs and boost to make power, everyone knows that so the longer you can safely hold it the better id say (in terms of how quick your goin, its not goin to be better for the motor hahaha)
I have learnt that the speedo and tacho seem to be close together
ie if speedo says 50kms it the tacho will say 3000rpm, if rsm says 50kms on it the rsm will say 3000rpm. Ive found the rsm from the dyno is perfect in terms of speed, so im using that as my rpm gauge aswell...
The speedo seems to be out more and more the faster you get, but you should note i have different rims/tyres to manufactor specs and thats probably why my speedo is out!
From the RSM i hit the limiter at 7500rpm :) If your usin 8800rpm you have balls unless you have a built motor LOL
Hope that helps Cogs
Edited by jazza08
that because it will be out by.. lets say 10%. so at 50kmh it will be out by 5kmh, but at 150kmh it will be out by 15kmh. speedo's are usually out by percantage, not by a fixed kmh.
jazza, i'd say that your rsm is accurate. your tacho needle probably just bounces up to that sort of rpm, but the motor isn't actually going that high.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
