Ok so recently me and few friends were driving along to the shops, and noticed a black R32 with space savers on.. We were like cool he must have popped a tyre and put a space saver on.
But then to our amazement he was driving along as if he had all 4 normal wheels on. Speeding a fair bit and cutting in and out of traffic etc etc..
Now not to long ago i noticed another black r33 with one space saver on.. Didnt think much of it then, but saw him aagin a few days later.. Again with space savers on.
Now today i saw him again driving with it on..
Dont you know that its not safe having it on for long periods of time?? Esp when you drive around like as if you had all normal rims on..
Sigh..
End rant..
Edited by siddr20
i'd slash their space savers to get them off the road and prevent an accident.
this space saver shit must be the new "look at me, I'm a fu(kwit" trend.......the 5" cannon exhaust and the 200 db blowoff and pidgeon in the engine bay trend must be on its way out.
Edited by lingeringsoul
He obviously doesn't pay attention to Skylines in the news or he would have seen the Skyline that crashed because they were driving too fast on a space saver. Didn't one of them die?
Yeah I think a guy and his partner died...and a little boy survived the crash?
But the the times i saw the r33 he was drivin normally..
The other r32.. well lets just say there was an accident waiting to happen..
ohh well not my problem in the end anyways!!
hahahah nice pic mr 32!!
This post has been edited by lingeringsoul: Today, 08:40 AM
Not possible.. :blink:
Read the title and thought "Gees.. this one's going to stir a pot, bit racist.."..
But no - it's ok - it's stupid people being stupid..
Saw a taxi drive driving with one the other day - dropping people off.. went to get the next fare, couldn't believe it..
I drove around with a space saver on cos I was having issues with my rims.. but never went over 60k/h or hit boost and never on there for very long ..
hahah sure slim sure..
nah its all good.. Im just lookin out for you guys lol..
it is true
i was following him to make sure everything is fine..
damn, im a good bloke.
I was one of the mates with Siddr20. Believe it or not, the 32 with the space saver had positive camber on the space saver wheel. I think you can all work out how positive camber comes about
Edited by Mr_G
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
