ok, so i cracked a piston in my old rb20. Just went out and purchased one from a front cut, seemed in really good nick, put it into my r32, slapped my 550cc inj, and my hks2530 on, and went and got the microtech tuned. everything seemed fine, the motor ran really smooth. - did notice oil pressure a tad lower than usual, but still good.
after getting it tuned i drove it to work and back a few times, not really thrashing at all. the other night, went for a hard run up through the hills, and noticed a REALLY loud lifter noise. had to pull over and check it out.
on idle it was sitting around the 15psi and even less mark on the oil pressure gauge.
the next morning i checked oil level properly, it was nearly full, and the lifter on no 3-4 intake side sounds like it is broken, its not your usual lifter "tick" its more like a "rattle"...
anyone got any ideas on the possible causes ??
I thought the same sound in my old RB20 was a sticky lifter. Then someone bought the engine and stripped it down; turned out the cylinder was suffering "piston slap".
ok, the oil pump is at the front of the engine behind the harmonic balancer isnt it? sorry, havent replaced an oil pump on an rb before.... ive pulled my old one apart but didnt take much notice of it, was more concerned about other things!
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
