Your answer - HKS F-CON V Pro (version 3.24 + only)
Now before the critics jump up n down waving their arms around; yes it is a piggyback :happy: But, it's better than a PFC, it works on the auto on Nissans and is one of the most popular ECU systems in Japan.
paying for the guy to come out and tune sounds really expensive
i live in Far north QLD and that in itself would be an expensive trip
let alone dyno hire costs etc
I have an r34 auto and im slowly narrowing down my options
but it seems my best bet is a dr drift tune if/when he comes up here
another option is the greddy emanage piggyback system but no one up here can tell me if it will work with the tiptronic auto (does it ???)
I should have bought a manual
Greddy Emanage does work; talk to 666Dan about it I think... there is a bit of DIY stuff you have to do to make it work though, something to do with the resistors?
Hopefulyl one day the HKS ECUs will become more tunable and let people from other states reap the same benefits.
I can wait - I'll just grab yours when you're finished with it Stan :P
I can wait - I'll just grab yours when you're finished with it Stan :laugh:
Useless in SA, can only be tuned by an auithorised HKS Tuning Shop using the HKS supplied dongle and software. Which HKS charges an arm and a leg for.
:( cheers :(
:( cheers :(
was tongue in cheek - anyway, Im sure Stan would love to pay for the 1st tune as part of the "deal"
lol, quite happy with the safc/sitc combo, cheers
:laugh::( :sorcerer:
According to some "rumors" which I'm yet to justify, there are other tuners out there for HKS ECUs... whether or not this is true I don't know.
SK; why you always shuttin me down for :( LOL it's all good... as you said, friendly discussions never hurt anyone :)
how do you adjust the air/fuel ratio with an safc when the factory ecu just keeps correting it via the o2 sensor?
The standard (slow and narrow) lambda sensor only works for constant throttle cruise and idle (generally called closed loop running). At ANY other loads (that's the other 99.9% of the time) the mapping has full control of the A/F ratios (open loop running).
:ninja: cheers :laugh:
I dont think it is as easy as that..... What is the throttle position? What is the AFR? How much load is it under?
When I had my safc tuned in my r33 it took them a good hour, and 4 or 5 dyno runs to get it perfect, and it bloody did well, gained 28rwkw and ~300kms EXTRA out of a full tank of petrol, was VERY happy!! :laugh:
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
